so its happened twice now the first time it was hard to make out just seemed like static chalked it up to my LED halos being wet and causing a issue immediately dissipated after restarting the car
after last night rain I went out to start the car and the static was there but it was rather consistent I turned the stereo to max before restarting the car this time
and the distinction of my engine firing in sync was incredibly obvious
right now my amp is wired into my fuse box
Should I move it and connect directly to battery?
seems like a bad ground somewhere but I'm not sure which to check between battery headlight and amp I have 4 grounds on the vehicle
and the fact that it only happens while wet and briefly would lead me to believe its moisture under the hood
I grounded the new lamps to the old grounding bolts but they dont offer the same spacing so there is about 1/4 inch gap around it that I need to weather strip
Anybody know a place where I could pick up some diy stripping to go around the gap with?
