Quote Originally Posted by Beelzeboul View Post
I run a 2700 watt amplifier with LED projector lights and an obd2 bluetooth adapter on an extreme hybrid battery
have had my charging system checked repeatedly for alternator or battery issues and a year later everything is still fine(knock on wood)
they do have alot of counter measures for high drain devices a friend once charged a power cap in his house and used it to power a tv for several hours
high output alternators are a little more expensive require some tool time but come with good warranties and and pretty easily swapped if problems do arise
in price range
Power cap
Battery
High output alternator
best bet is to check your system regularly
2700W clamped or rated?
I have 2 2500W amps strapped at 1ohm .5ohm per amp should be getting 5500-6kw on my stock alt
Caps are good for 1-2 seconds tops so..... good if your going for a burp
