Thread: Hi lo equalizer question
Results 1 to 20 of 20
  1. #1 Hi lo equalizer question
    the desert
    if i have an equalizer for my rca's do i still need a hi low converter when i hook up an amp and speakers? Im planning on keeping my radio stock. Thanks
  2. #2 Re: Hi lo equalizer question
    Houston
    If you have a separate EQ, no. Use the outputs from that. Haven't seen an EQ used it quite some time. But know that the signal is gonna be crossed over at whatever your EQ is set at.
  3. #3 Re: Hi lo equalizer question
    the desert
    ok well lets say i dont run an eq. i want to run 4 amps. front, rear door, rear deck, and sub woofer. i know how i would split all the power and the remotes but where would all those rca's go to? Still planning to keep it stock
  4. #4 Re: Hi lo equalizer question
    the desert
    stock head unit*
  5. #5 Re: Hi lo equalizer question
    the desert
    im guessing a multi line output converter?
  6. #6 Re: Hi lo equalizer question
    Houston
    Quote Originally Posted by mcsddd View Post
    Uh...mmm....
    We need to start over. What do you have now, and what are you trying to do?
  7. #7 Re: Hi lo equalizer question
    the desert
    alright well this setup is going to be for my lexus but i have a pontiac too so i thought i might as well ask both forums and get input. I would like to run 3 amps. a 4 channel for the door speakers, a 2 channel for a rear deck speaker and a mono for a sub. but the 4 channel amp is too expensive and i already have a 2 channel amp layin around so i figured id just do a 2 channel for front doors, 2 channel for rear doors, 2 channel for rear deck, and mono for the subwoofer. I know how to split up the power wires and the remote wires but i didn't know where all the rca's would go. but im doing more research and i see there is a 8 channel multi line converter and i think that would work. If you have any other ideas i would greatly appreciate the help.
  8. #8 Re: Hi lo equalizer question
    Houston
    What year/model pontiac? What amps are you working with? The year/model of car is important so we can find where you full range signals are. You may be able to get away with just one 4 channel LOC. Depends on if your amps have outputs. If they do, you can link them (daisy chain).
  9. #9 Re: Hi lo equalizer question
    the desert
    actually since i have both a line in and line out on my mono amp i could go from the converter to the line in on the mono amp then the line out on the mono amp to the line in of the 2 channel amp
  10. #10 Re: Hi lo equalizer question
    the desert
    we posted our post at the same time lol. So im guessing i can "daisy chain"
  11. #11 Re: Hi lo equalizer question
    Houston
    Yes...but you're looking at running 4 amps. You're signal will decrease from amp to amp to amp to amp......
  12. #12 Re: Hi lo equalizer question
    the desert
    isnt that where the 4 channel output converter comes in. I can daisy chain 2 amps to the first two channels then daisy chain the other 2 amps to the other two channels. correct? instead of amp to amp to amp to amp correct? or is there a better way?
  13. #13 Re: Hi lo equalizer question
    the desert
    sorry for all the corrects? lol im just typing fast and not really proof reading
  14. #14 Re: Hi lo equalizer question
    Houston
    LoL....yeah, a 6 channel and a monoblock. But with what you're working with, it will work. You want to make sure to pull a full range signal to your LOC. Can't remember on the Lexus' which lines were the full range.
  15. #15 Re: Hi lo equalizer question
    the desert
    so pretty much an 8 channel? lol and for the remote wires i should use a relay to distribute the power right?
  16. #16 Re: Hi lo equalizer question
    Houston
    Definitely with that many amps. 86 to turn on lead, 30 to constant 12v, 85 to ground, and 87 to amps.
  17. #17 Re: Hi lo equalizer question
    the desert
    so you would hook everything up to the right number (86,30,85,87) then you would daisy chain the amps? or do you hook all 4 remote wires up to 87
  18. #18 Re: Hi lo equalizer question
    Houston
    You could do it either way. It may get crowded on post 87 with 4 wires in one spade.
  19. #19 Re: Hi lo equalizer question
    Sep 2011
    Arkansas
    You could just run a stout 4 channel, such as the Crescendo C1100.4. It's 1 ohm stable on each channel...
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  20. #20 Re: Hi lo equalizer question
    the desert
    ok thanks. i have another question. the rear deck is just going to be one 10 inch speaker. the speaker is rated at 250w rms at 8 ohms. how do i get an amp to match that? most amps i see are at 4 ohms. Im pretty sure i need a mono amp for that speaker but idk where to find one to match the speaker
  1. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  2. Don't understand the equalizer
    By OKExplorist in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2012, 11:07 AM
  3. LED Equalizer
    By iceman977th in forum Audio, Security & Visual Electronics
    Last Post: 12-06-2010, 01:17 PM
  4. Stock HU Equalizer problem
    By jrsmith313 in forum Audio, Security & Visual Electronics
    Last Post: 11-17-2010, 09:07 PM
