Thread: System Upgrade
Results 1 to 2 of 2
  1. #1 System Upgrade
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    What do you guys think? Right now i have 2 mtx audio 12s with a 1500 watt American Bass amp, 1 sub blew because i cranked my bass boost all the way up...oops Opinions wanted
    • 1 Ohm Stable Class D Mono Block Amplifier
    • Low Level Input and Output
    • Frequency Response: 15Hz ~ 270Hz
    • Input Level: 6V ~ 0.2V
    • Variable Subsonic: 10Hz ~ 50Hz
    • Variable Low Pass Filter: 35Hz ~ 250Hz
    • Variable Bass Boost: 0 ~ 9db
    • S/N Ratio: >85
    • THD: 0.1%
    • Remote Gain Controller
    • Two Amplifiers Linkable Connector and Selector
    • Fuse Rating: 120 Amps, Linked Fuse Rating: 240 Amps
    • 3500 Watts Max
    • 1600 Watts RMS
    • Dimensions (Inches)
    • Height: 2.18
    • Width: 9.13
    • Lemgth: 16.53
    2 of these 15's
    • Impedence (Ohm) 4
    • Rdc (Ohm) 3.5
    • Levc mH 3.783
    • Fo Hz 30.4
    • Sd msqM 76.45
    • BL TM 16.295
    • Qms 4.764
    • Qms 4.764
    • Qes 0.635
    • Qts 0.56
    • n% 0.375
    • SPL dB 89.8
    • Vas L 89.6
    • Cms uM/N 105.6
    • Mms g 259.6
    • VC Inch 2.5
    • Mgnt oz 120
    • Xmax ±MM 15
    • RMS 500W
    • MAX 1000W
    • F.Range Hz <500
    • Mounting Depth
    • MM 228
    • Inch 9
    • SPK DISP. L 6.824
    Im getting all this with enclosures for $470, regular price $670 but giving back my 1500 watt amp for $200 which i paid for originally from the guy.
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
  2. #2 Re: System Upgrade
    Topeka, KS
    I think you should unhook the bassboost knob and forget it even exists. All those things do is create distortion. Why not do one single 12 or 15 off of that amp. I mean 470's not terrible for all of that though.
    Ever heard of Sundown Audio? Get one of those subs and be amazed.
  1. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  2. 2004 Grand Prix GT. Service ABS System, and Taction Control System
    By Erika Schultz in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2012, 05:26 PM
  3. Fuel System Upgrade
    By Pure2sin in forum Engine
    Last Post: 03-25-2012, 04:28 AM
  4. 2002 GT budget system upgrade suggestions
    By 2002red in forum Audio, Security & Visual Electronics
    Last Post: 01-08-2011, 08:36 PM
  5. Full sound system upgrade, amplifier help
    By deathjunior in forum Audio, Security & Visual Electronics
    Last Post: 12-08-2010, 01:21 PM
