Thread: Kenwood
Results 1 to 8 of 8
  1. #1 Kenwood
    Jun 2012
    Golden Eagle, IL
    ok so i have an 04 gp gt i have two 12 kenwood subs on a small kenwood amp ( it all was a package deal) and i just put in a new jvc double din head unit, i have noticed that after driving a while say 40 miles, the subs start to cut out. If i stop and leave the car running and open up the back seat you can watch the amp light go out and come back on after a sec. what should i do to rid of this problem, thanks
  2. #2 Re: Kenwood
    GTP Level Member simbah's Avatar
    Lala land
    First question is how do you have it wired, wire size and where do you have it grounded?
    Second question is where do you have the gain set on the amp?
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: Kenwood
    Houston
    Could be a loose connection. Could also be the amp overheating and shutting down.
  4. #4 Re: Kenwood
    Jun 2012
    Golden Eagle, IL
    im thinking its the amp overheating, i had the same setup in my 90 f-150 pickup and it worked fine
  5. #5 Re: Kenwood
    Jun 2012
    Golden Eagle, IL
    how should i fix this problem
  6. #6 Re: Kenwood
    Yoga city
    check the ohm load on amp, is it stable? turn gains or bass boost off. u got a mulitmeter?
  7. #7 Re: Kenwood
    Jun 2012
    Golden Eagle, IL
    how do i check that stuff and yea i got a mulitmeter
  8. #8 Re: Kenwood
    Yoga city
    for one turn your meter on to read volts dc then check what you read at the battery. then compare that to voltage at amp. if you have a drop prolly bad ground.
    turn the meter to ohms and read what the + and - read at the amp. not sure what your amp is rated for but usally 4 ohms bridged and 2 ohm stereo so let me know
  1. Kenwood KVT-512 Indash dvd with GPS
    By MrClean in forum Buy/Sell Other/Misc
    Last Post: 04-11-2012, 08:15 PM
  2. FS: Kenwood KAC-2404S 4-3-2 Amp (New)
    By BlownBigBlock in forum Buy/Sell Other/Misc
    Last Post: 01-02-2012, 11:33 AM
  3. NEW Kenwood HU and Ipod pops
    By bjm306 in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2010, 08:21 AM
  4. Kenwood Audio
    By GTPJOE90 in forum Audio, Security & Visual Electronics
    Last Post: 08-27-2008, 10:59 PM
