Thread: System Upgrade
Results 1 to 2 of 2
Threaded View
  1. #1 System Upgrade
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    What do you guys think? Right now i have 2 mtx audio 12s with a 1500 watt American Bass amp, 1 sub blew because i cranked my bass boost all the way up...oops Opinions wanted
    • 1 Ohm Stable Class D Mono Block Amplifier
    • Low Level Input and Output
    • Frequency Response: 15Hz ~ 270Hz
    • Input Level: 6V ~ 0.2V
    • Variable Subsonic: 10Hz ~ 50Hz
    • Variable Low Pass Filter: 35Hz ~ 250Hz
    • Variable Bass Boost: 0 ~ 9db
    • S/N Ratio: >85
    • THD: 0.1%
    • Remote Gain Controller
    • Two Amplifiers Linkable Connector and Selector
    • Fuse Rating: 120 Amps, Linked Fuse Rating: 240 Amps
    • 3500 Watts Max
    • 1600 Watts RMS
    • Dimensions (Inches)
    • Height: 2.18
    • Width: 9.13
    • Lemgth: 16.53
    2 of these 15's
    • Impedence (Ohm) 4
    • Rdc (Ohm) 3.5
    • Levc mH 3.783
    • Fo Hz 30.4
    • Sd msqM 76.45
    • BL TM 16.295
    • Qms 4.764
    • Qms 4.764
    • Qes 0.635
    • Qts 0.56
    • n% 0.375
    • SPL dB 89.8
    • Vas L 89.6
    • Cms uM/N 105.6
    • Mms g 259.6
    • VC Inch 2.5
    • Mgnt oz 120
    • Xmax ±MM 15
    • RMS 500W
    • MAX 1000W
    • F.Range Hz <500
    • Mounting Depth
    • MM 228
    • Inch 9
    • SPK DISP. L 6.824
    Im getting all this with enclosures for $470, regular price $670 but giving back my 1500 watt amp for $200 which i paid for originally from the guy.
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
  1. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  2. 2004 Grand Prix GT. Service ABS System, and Taction Control System
    By Erika Schultz in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2012, 05:26 PM
  3. Fuel System Upgrade
    By Pure2sin in forum Engine
    Last Post: 03-25-2012, 04:28 AM
  4. 2002 GT budget system upgrade suggestions
    By 2002red in forum Audio, Security & Visual Electronics
    Last Post: 01-08-2011, 08:36 PM
  5. Full sound system upgrade, amplifier help
    By deathjunior in forum Audio, Security & Visual Electronics
    Last Post: 12-08-2010, 01:21 PM
