Thread: strange lighting issue
Results 1 to 13 of 13
  1. #1 strange lighting issue
    Jan 2012
    Abilene, KS
    just recently i got in my car to leave from work at night and my radio light wouldnt come on. so i figured oh its just burned out or whatever. so i got up and went to work the next morning and half of the DIC was really dim. i went over the railroad tracks and it all came back on. i turned onto the gravel road and my dic went back out but this time all the way.
    After i got off that day my radio light was on so i was thinking wth but it is what it is and i aint gonna worry. my dic was still and i hit the top of my dash and it came back on with out any problems. Now the DIC is hit and miss as to which half is lit up or if its lit up at all or if all of it is lit up.
    For the radio on the other hand i was turning my knob for my manual headlight controls when i noticed it came on for a split second so i turned it back. I noticed there is one spot right in the middle off the auto and the next spot.
    One time the light around the 60 mph went out but came back like 5 minutes later without hitting a bump or anything? anyone else have any similar problems? or any help?
    I also wasn't getting any power to my a/c compressor and my passenger side window had a short time when it wouldnt roll up or down and sometimes it would only go one way but not the other. i finally got it all the way up after a real nice temper tantrum(or however thats spelled) and now it wont go up or down at any point in time but im not sure if it would be related
  2. #2 Re: strange lighting issue
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    Sounds like you have a wiring problem take of the DIC and the radio and see if there are any wires that look bad. Also wouldn't hurt to look around the fuse boxes
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  3. #3 Re: strange lighting issue
    Jan 2012
    Abilene, KS
    i have already checked the fuse box and nothin there but im not sure when ill get a chance to look at the other wires. one more thing to add im not sure if its related or not but when i bought it had just had the trans rebuilt like 5k before i got it. when i push the performance shift button it lights up on my dic but i think it should light up on the instrument clustr too but i cant feel a difference between when its on and off
  4. #4 Re: strange lighting issue
    Jan 2012
    Abilene, KS
    any other ideas?
  5. #5 Re: strange lighting issue
    Jan 2012
    Abilene, KS
    still no ideas
  6. #6 Re: strange lighting issue
    Feb 2010
    TN
    I say check your ground wire
  7. #7 Re: strange lighting issue
    Jan 2012
    Abilene, KS
    I figured maybe that but wouldn't that cause more things to have problems?
  8. #8 Re: strange lighting issue
    Feb 2010
    TN
    Not always
  9. #9 Re: strange lighting issue
    GTX Level Member blackflag's Avatar
    Virginia
    Ignition switch
  10. #10 Re: strange lighting issue
    Virginia
    also, sounds like all issues are not related.
    Dic radio and headlight controls run through ign switch. More than likely your hvac will only work on 5 after awhile and other electrical issues will pop up
  11. #11 Re: strange lighting issue
    Jan 2012
    Abilene, KS
    hmm is it difficult to replace the ignition switch or should i wait til other more serious problems pop up?
  12. #12 Re: strange lighting issue
    Jan 2012
    Abilene, KS
    and another thing to add my low coolant light is on but i have plenty of coolant and i have bled it too
  13. #13 Re: strange lighting issue
    Jan 2012
    Abilene, KS
    old thread but i replaced my ignition switch blower motor and dic work but the lights on the radio still go off when i turn on my lights. checked all my grounds and there clean.
  1. strange KR issue i have had... very small numbers
    By Z34Phoenix in forum PCM Tuning
    Last Post: 06-05-2012, 06:32 PM
  2. Interior Lighting Issue
    By RaiderGT in forum General Tech Discussion
    Last Post: 01-30-2012, 08:55 PM
  3. strange issue
    By GTP Push in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2011, 03:16 PM
  4. Strange 2nd gear issue/Scan Tool Advise
    By Higgins428 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2009, 05:17 PM
  5. strange issue?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-29-2008, 12:27 AM
