Thread: Avital 4103 timer mode disable?
Results 1 to 2 of 2
  1. #1 Avital 4103 timer mode disable?
    Florida
    I installed this unit myself on my GTP, and didn't realize that it had been starting itself via the timer mode. I don't have the car tagged and I don't drive it because of that. I'm rarely at home more than a couple hours or asleep, but today I noticed the car starting itself twice in about a 3 hour time period. I thought that maybe something had been set on the remote and pushed the button. I looked over the manual again but I can't seem to figure out how to disable this feature. I've googled it but specifically for this model I can't find anyone with a similar issue. I've listed the link to the manual below, perhaps someone else can figure it out for me. I do see on the Mode 1 and Mode 2 tables at the bottom of the second one on 11 it says Timer Mode Run Time and it lists 12, 3, 6, 9 but farther down in the book for an explanation of that 11 it says 0, 3, 6, 9 so is it a misprint or what? How can I disable the car from starting itself?
    http://www.directeddealers.com/manua...008-07_web.pdf
  2. #2 Re: Avital 4103 timer mode disable?
    Houston
    There is a known antenna issue with that unit. You may have accidentally put it into timer mode by pressing lock and unlock at the same time. Wait till it starts on it own again and go out an turn the ignition on. It should flash the lights 4 times. If that don't work, change your pulse setting for the remote start to 2 pulse.
  1. First-timer says Hello
    By JFBenedetto in forum Introductions/Noob Questions
    Last Post: 11-08-2011, 03:38 PM
  2. Dome Lamp Disable Mode
    By Scanner in forum General Tech Discussion
    Last Post: 10-12-2010, 09:32 AM
  3. just another 1st timer saying hi, from nc.
    By ak47 in forum Introductions/Noob Questions
    Last Post: 07-31-2010, 02:34 PM
  4. Yep, I'm a 1st timer!
    By telkel2399 in forum Introductions/Noob Questions
    Last Post: 12-05-2009, 07:06 PM
  5. First Timer
    By kygtp in forum Introductions/Noob Questions
    Last Post: 10-22-2008, 10:27 AM
