Thread: Factory Alarm 5 beeps
Results 1 to 2 of 2
BlackSun Factory Alarm 5 beeps 01-10-2012, 06:16 PM
gpse2000 Re: Factory Alarm 5 beeps 06-15-2012, 07:23 PM
  1. #1 Factory Alarm 5 beeps
    Nov 2010
    Marine City MI
    My factory alarm on my 99 GTP beeps 5 times, about a minute after I set it. It happens at least twice a day, any idea what's going on? Also it doesn't matter if I push the button once or twice either.
    99 GTP, ZZP MPS 2.9 pulley, GenIII supercharger ported & polished, machined intake W/ stage 2 intercooler, XP Cam,ZZP fuel rails, 42.5 injectors, Wizard CAI, custom headers, 3 inch downpipe, into dynomax muffler,180 stat, Northstar TB, 85mm MAF, ZZP trans, 3.29 gears, input shaft and torque converter, stock heads W/Ls6 springs.
  2. #2 Re: Factory Alarm 5 beeps
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    My 2000 does this for an easy fix I usually just use the fob to lock the doors while I still have the driver one open then unlock once so just the driver door unlocks then I manually lock the driver from the inside. This doesn't activate the alarm which causes the horn to go off randomly
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  1. Factory alarm sensitivity
    By gpse2000 in forum Audio, Security & Visual Electronics
    Last Post: 08-23-2011, 05:22 PM
  2. Factory Alarm disabled?
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 10-18-2009, 03:09 PM
  3. Factory alarm for 98 GTP
    By tjvdubsport in forum Audio, Security & Visual Electronics
    Last Post: 07-11-2009, 09:39 AM
  4. Disable Factory Alarm?
    By TheDesertFox in forum Audio, Security & Visual Electronics
    Last Post: 04-12-2009, 10:24 PM
  5. Does my GP have a factory alarm?
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 03-23-2008, 10:48 AM
