Thread: Disable Factory Alarm?
Results 1 to 7 of 7
TheDesertFox Disable Factory Alarm? 04-09-2009, 09:34 AM
TheDesertFox Re: Disable Factory Alarm? 04-10-2009, 08:19 AM
chrisb Re: Disable Factory Alarm? 04-10-2009, 11:02 AM
TheDesertFox Re: Disable Factory Alarm? 04-11-2009, 09:47 AM
gotboost3 Re: Disable Factory Alarm? 04-11-2009, 10:20 AM
TheDesertFox Re: Disable Factory Alarm? 04-12-2009, 10:06 AM
millfire517 Re: Disable Factory Alarm? 04-12-2009, 10:24 PM
  1. #1 Disable Factory Alarm?
    SE Level Member TheDesertFox's Avatar
    Feb 2009
    Orrtanna
    My alarm randomly goes off at night. It will only go off 4 times, but it might do it several times a night. As you can guess, it is very annoying at all hours of the night. I turned the alarm sensitivity down from level 4 to level 2 and STILL the alarm goes off.
    So my question is, is there anyway to disable the factory alarm?
  2. #2 Re: Disable Factory Alarm?
    Feb 2009
    Orrtanna
    Any ideas on how to disable this thing?
  3. #3 Re: Disable Factory Alarm?
    Donating Users chrisb's Avatar
    Bucyrus, OH
    how do you turn the alarm sensitivity down? mine does this all the time
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  4. #4 Re: Disable Factory Alarm?
    Feb 2009
    Orrtanna
    Quote Originally Posted by chrisb View Post
    I'm sorry, but I had my friend come over with his owner manual (my car didn't come with one) and he showed me how it's done. You have to remove a fuse and turn your car to the accessory mode I believe. Like I said I turned mine down and it STILL goes off, so I want the alarm gone all together.
  5. #5 Re: Disable Factory Alarm?
    Donating Users
    Plainfield, IL
    ok you have two options...
    1. you can look under the dash right above the gas pedal but but more toward the back of the car you will find the shock sensor it is a small flat square with rounded edges and it has a white sensitivity knob on it that you can adjust its prob turned up too high.
    2. you can go to the bcm also under the dash all the way on the left above your left foot if you were driving....on the bcm there is a 20 pin connector (all the thin wires) connector farthest toward the front of the car....you need to find the orange wire with a black stripe and ground this wire from the bcm side to a good ground and you will have your alarm disabled and still have keyless entry etc. etc. just no alarm good luck!
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  6. #6 Re: Disable Factory Alarm?
    Feb 2009
    Orrtanna
    Thanks man!
  7. #7 Re: Disable Factory Alarm?
    SE Level Member millfire517's Avatar
    Jan 2009
    Indiana
    hey thanks for posting this, i was coming here for the same dang reason.
    1998 Pontiac Grand Prix GTP 4dr red. all stock with 185,xxx miles.
  1. How to disable my day time running lights ??
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2010, 08:54 PM
  2. disable lockup 1999 regal gs
    By smokingjoe in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-25-2010, 10:35 AM
  3. DRL disable
    By 99prixgt in forum Visual/Body Modifications
    Last Post: 12-16-2008, 09:33 AM
  4. Disable Supercharger
    By Minor723 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-11-2008, 10:11 PM
  5. Does my GP have a factory alarm?
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 03-23-2008, 10:48 AM
