Thread: "ANOTHER" Extremely Hot AMP
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #1 Re: "ANOTHER" Extremely Hot AMP
    GTP Level Member
    Nov 2011
    Kansas
    Never hurts lol. I havent really had to deal with hot amps. I think if you get it close to correctly tuned it will help a lot. Then you may take it in and ask if they can double check your work.
  2. #2 Re: "ANOTHER" Extremely Hot AMP
    London Ont, Canada
    did you melt one? or just wanting to replace them because hot?
  3. #3 Re: "ANOTHER" Extremely Hot AMP
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    Quote Originally Posted by develand View Post
    Lucky you, i still have this huge feeling that part of my problem is that i could be needing a higher watt kit.
    No havent melted 1 or anything. But do you see my last amp? It was pretty small trying to power up my subs. I got a bigger 1 to see what that would do, got me more power but that amp gets hotter quicker...
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
  4. #4 Re: "ANOTHER" Extremely Hot AMP
    Mar 2012
    NC
    What impedence is/are the subwoofer(s) you're trying to power?
  5. #5 Re: "ANOTHER" Extremely Hot AMP
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    Get a D Class amp don't have the gain above 3/4
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  6. #6 Re: "ANOTHER" Extremely Hot AMP
    Donating Users Tengis's Avatar
    Houston
    A gain knob is not meant to be a volume knob... -_-
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  7. #7 Re: "ANOTHER" Extremely Hot AMP
    Minnesota
    No offence and people will get mad about this but...Get a good amp and this won't happen. Hence the reason you have to turn the gain all the way up to make it sound good.
    That Sony amp is $99.00 on Ebay. It has specs of 400wx1 RMS at 4 Ohms and 380wx2 MAX power at 4 Ohms.
    Have you checked the ground?
  8. #8 Re: "ANOTHER" Extremely Hot AMP
    Yoga city
    uhm i would check for voltage drop when playing your stereo. loads being on bad ground can cause heat also so check everything.upgrade the engine/chasis grounds along with a run from alternator to battery
  9. #9 Re: "ANOTHER" Extremely Hot AMP
    Dec 2010
    ATL,Georgia
    How do you have your subs wired? If you wired them too low of an impedance(ie parallel ) then that could be your problem right there.
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. lost "D" and "3" the car only move forward in 2nd
    By asite57 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-16-2012, 11:17 AM
  3. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  4. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
