Thread: ignition switch questions. help me out please.
Results 1 to 7 of 7
  1. #1 ignition switch questions. help me out please.
    Yoga city
    well everyonce in awhile i will start my car and it will start but none of the gauges or anything works, just lights. i had a code for ignition something so if i just replace it you think this will all go away? and being i have an 2005 will there be anything that will need to be prgrammed by dealer?
  2. #2 Re: ignition switch questions. help me out please.
    Ohio
    no just replace the ignition switch and hopefully that should be it. the switch is a common gm problem around these years. most people i know with 05-06 cobalts and gp's have had to replace theirs.
  3. #3 Re: ignition switch questions. help me out please.
    Yoga city
    ok thanks, i need to look around for some othere stuff in the process, stupid list of codesim boggled by some
  4. #4 Re: ignition switch questions. help me out please.
    Pennsylvania, USA
    This has happened once or twice with my 05 as well, I'm hoping it doesn't become a regular thing or I'll be replacing my ignition switch as well :/
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Does your DIC flake out too? Mine does this thing where the AC and all gauges but speedometer shut off. My DIC will flash random service this or that errors won't show trans temp, voltage and gas stats. 2005 gpgt. To fix it I have to shut off the car take key out of ignition open drivers door, close, arm aftermarket alarm, disarm, open and close driver door start car.... so stupid.
    Sent from my Galaxy Nexus using Tapatalk 2
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  6. #6 Re: ignition switch questions. help me out please.
    Yoga city
    That sounds like bad bcm if you have that crazy pattern
    Apr 2012
    Middletown DE
    at first I thought it was BCM but reading around the GM forums it might be the Viper 5900 I had installed
    1993 Oldmobile 88
  1. ignition switch help
    By redrivergar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-02-2010, 09:13 PM
  2. ignition switch
    By mtz956 in forum General Tech Discussion
    Last Post: 08-10-2010, 04:53 PM
  3. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
