Thread: Thinking about a new sub...
Results 1 to 18 of 18
  1. #1 Thinking about a new sub...
    Mar 2012
    NC
    So, I'm thinking about selling my subs to downsize to one 10" subwoofer installed in my right rear quarter area. I currently have two JL 12w6v2's and a JL 1000/1v2. I would like to use the 1000/1 on my new sub. So far, I've looked into the Image Dynamics IDMAX 10 v.3 but haven't found much else that will support the power if I want to turn it up. I like the clean bass of the JL's, but the weight and lack of trunk space are killing me. Any suggestions?
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Alpine type R's for sure. A 15 inch needs a 4 inch ported box though. So a 10 would probably need a 2 inch
  3. #3 Re: Thinking about a new sub...
    Mar 2012
    NC
    Looking to go sealed. Tired of not having my trunk space.
    Mar 2012
    Minneapolis MN
    You can put ports in the side of a box too. So it only needs to fit width and depth, and not have the extra space taken up on the side. As for sealed though, I can't help you. I'm a super strong believer in ports.
  5. #5 Re: Thinking about a new sub...
    Mar 2012
    NC
    The only reason I want a sealed enclosure is for space savings. Any ideas on 10" subs capable of handling 1000w continuous and capable of living in a relatively small enclosure?
  6. #6 Re: Thinking about a new sub...
    Nov 2009
    illinois
  7. #7 Re: Thinking about a new sub...
    Yoga city
    ^ this or a sundown sa-10?
  8. #8 Re: Thinking about a new sub...
    Pennsylvania, USA
    Fi Audio makes some solid subs that can handle a ton of power, an SSD is about $200-$250 depending on the options you pick, but it will get loud and stay clean.
    https://ssl.perfora.net/www.ficaraud...iew.shopscript
    The Q is a step up, the price reflects that, but after hearing one in a properly built sealed enclosure with about 1800W, I have to admit that I haven't heard a cleaner sounding sub get that loud in person since.
    Then again I've also never heard the DC or the Sundown in person.
    Not tryin to bag on you Kolton, Alpine is a very reputable brand that makes quality subwoofers, but after finding smaller companies like these^ I find it hard to justify the price tag of any Alpine, Rockford, Kicker, etc.
    Stupid thing is that I still don't have money for my new build due to car repairs/upgrades and bills, so I actually own two Rockford P3's, the newer ones with the aluminum cone. They're loud and pretty accurate, but meh...
  9. #9 Re: Thinking about a new sub...
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    look into Skar Audio similar to Sundown but more SQ/sealed oriented
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
    Mar 2012
    Minneapolis MN
    No biggie man I know their prices are way too high. I just usually tell people the names of companies they know, the small companies are the winners. It's really the same product but for a real, and reasonable price. I got my Polk Audio db 212-2's before I did much research into lesser known brands, and I assure you, I will be going with one of the small companies when/if my db 212-2's ever die.
  11. #11 Re: Thinking about a new sub...
    SE Level Member Iced Iridium's Avatar
    Dec 2011
    Daytona Beach, Florida, United States
    Cadence is another brand to look into. Had a pair of their ~1996 UltraDrive series that were rated at 300Wrms each that took quite a pounding and are still kickin in a friend's car. My next sub will probably be from their S2 series.
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    This or AudioQue or Digital Designs. I have 2 12inch hdc's from AQ atm.
    Sent from my Galaxy Nexus using Tapatalk 2
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  13. #13 Re: Thinking about a new sub...
    Cedar Rapids, IA
    AudioQue is no more is SQ... personally can't say i'd ever run AQ/SQ again, they have a sound to them i just don't like, with that said i do respect the HDC4 just for the money wouldn't ever run it. I like my Sundown, the SA-12s took everything i could throw at them. 4kw on a sub for 3 min (clipping) and still lived, the only weak spot I've found was when i had them in the NightShade box that has wayy to much port for SA's and ripped a surround.
    Owned RF, Dual, Kicker, AQ/SQ, Sundown.
  14. #14 Re: Thinking about a new sub...
    GTP Level Member
    Nov 2011
    Kansas
    If you like JL, why not get the 10w6..... you should be able to sell both 12's and get one. Or a 10w3 if you dont want as much. I am a JL guy, so I say stick with it.
  15. #15 Re: Thinking about a new sub...
    Nov 2009
    illinois
    Quote Originally Posted by 1LoudGrandPrix View Post
    skar is another good brand. They have a new line coming out good for 1500w. Would be just fine on 1000w and would still have room for more power if you ever wanted to use a bigger amp.
  16. #16 Re: Thinking about a new sub...
    Mar 2012
    NC
    Quote Originally Posted by develand View Post
    It's not that I don't like JL...I've been using JL for the past 10 years. The problem is I have a 1000/1v2 that I don't want to get rid of because of its flexibility and how well it works, but I want to downsize for weight and space savings while still having the thump and sound quality I'm used to...if not more.
    So far, I'm really liking the Fi Audio SSD10 for its ability to fit in a tiny enclosure while being loud and clear, and I can customize little things about it. Please keep the suggestions coming! I had no idea a lot of these companies existed.
  17. #17 Re: Thinking about a new sub...
    Apr 2012
    Middletown DE
    AQ is all about the SPL, the SQ sucks, I'd love L3's due to them being SQ and SPL and they can be abused if you wanted to put them through hell :3
    I was on the right, clipped them to death that day, had to send them in for a recone.
    1993 Oldmobile 88
  18. #18 Re: Thinking about a new sub...
    Sep 2011
    Arkansas
    Hmmmm... small enclosure, plenty of trunk space. You could run 2 8" subs ported on that 1000/1 and have some serious thump in a seriously small package. Look into the Sundown SA-8 and the Skar vvx-8. If you want one 10", there are plenty of subs that can take that 1k without breaking a sweat. The sundown SA-10 and Skar vvx-10 are two choices that have already been mentioned, and are proven performers. There's also the Sundown Zv3 10, but I doubt you're looking for anything that monstrous. Besides, that 1k would just tickle it lol.
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  1. OK thinking about going BIG
    By Louie3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2010, 02:19 PM
  2. Thinking about getting a gtp have around 10k
    By jmj4492 in forum General Tech Discussion
    Last Post: 10-25-2009, 09:19 AM
  3. Thinking of getting rid of my gxp
    By Cableguy in forum Off Topic Discussion
    Last Post: 01-16-2009, 08:35 AM
  4. Thinking about getting these...
    By Quicklynx in forum Off Topic Discussion
    Last Post: 10-21-2008, 10:30 AM
  5. thinking about
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-14-2008, 12:36 AM
