Thread: Aeroforce Issue - not really turning on....
Results 1 to 20 of 24
  1. #1 Aeroforce Issue - not really turning on....
    Jun 2010
    ontario
    I have an Aeroforce Interceptor Gauge (Gen1 IIRC) and its having issues powering up
    The issue i'm having is that the gauge has a mind of its own basically, sometimes it turns on by itself and it also turns of by itself, sometimes if you tap the gauge it turns on, the wiring is good now, thanks to Jordon! now just have to figure out the rest...
    Jordon (Mad Monkey) helped out quite a bit, checked the gauge and everything in the gauge looked okay, everything was intact
    I would really like to have the gauge working
    any suggestions of what i should do? what i should look for? any help is appreciated
    TIA
    -Mike
    2005 Pontiac Grand Prix GXP ​Stock
    1997 Pontiac Grand Prix GTP loaded with lots of goodies
  2. #2 Re: Aeroforce Issue - not really turning on....
    London Ont, Canada
    his original wiring was cut and just twisted together, so i chopped it up, soldered and heat shrink tubed the lines for good connections.
    the gauge itself is intact like he said, nothing loose or looking damaged. it just powers up sometimes and not others.
  3. #3 Re: Aeroforce Issue - not really turning on....
    Grand Rapids, MI
    is it still under warranty? i had aero replace my power board when it fried.
  4. #4 Re: Aeroforce Issue - not really turning on....
    Jun 2010
    ontario
    i'll talk to the previous owner and see if its still under warranty, but i highly doubt it
  5. #5 Re: Aeroforce Issue - not really turning on....
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    For hooking it up to power you can always tap into an unused fuse space that only has power going to it when the car is on/acc. This may help a little bit so it is not constantly on and will turn off when the car turns off. I would also double check your ground. This is all being said with having no knowledge on an aeroforce gauge.
  6. #6 Re: Aeroforce Issue - not really turning on....
    Ohio
    are you using just the obd port for power???
  7. #7 Re: Aeroforce Issue - not really turning on....
    Jun 2010
    ontario
    its hooked up to the sunroof fuse, so no matter what, its off at power, only when the ignition is on, this happens
    i should've been more specific, sorry
  8. #8 Re: Aeroforce Issue - not really turning on....
    Ohio
    its fine. you used an add a fuse right?
  9. #9 Re: Aeroforce Issue - not really turning on....
    Jun 2010
    ontario
    no lol but its getting power via (kinda redneckish) putting the power supply wire into the bottom part of the sunroof fuse then put the 20 back in, would that be causing it? this was happening with the previous owner as well, normally when you flick or tap the gauge, sometimes it turns on, sometimes not, sometimes it turns itself off, i will be trying to get an add a fuse if need be this weekend
    Jordon and i were thinking a board could be having an issue...
  10. #10 Re: Aeroforce Issue - not really turning on....
    Nov 2009
    Add a a fuse to a place where there is no fuse currently. ALWAYS ADD A FUSE!!!!!!!!
  11. #11 Re: Aeroforce Issue - not really turning on....
    Ohio
    yeahhhhh you dont need 20 amps either. you're overloading it -_- use the mall pgm fuse and an add a fuse.
  12. #12 Re: Aeroforce Issue - not really turning on....
    Jun 2010
    ontario
    my car has a fuse for the sunroof, so what i did was find out what side of the fuse the current is running to and put the wire on that side of the fuse, this way power is running through the 20 that is there, powering the sunroof and aeroforce, if it were too much current that sucker would pop it was a temporary thing, but will be fixed soon
    ---edit---
    so use the PGM fuse rather then the sunroof fuse?
    from the write up i seen to install, it was said to use the sunroof
    whats the recomended fuse for a sunroof? also its a 10 for the aeroforce... right?
  13. #13 Re: Aeroforce Issue - not really turning on....
    Ohio
    lol yeah just pull the wire off that fuse. and no the fuse is not overloaded....the gauge is. it wont work with 20 amps...way too much.
  14. #14 Re: Aeroforce Issue - not really turning on....
    Nov 2009
    Quote Originally Posted by 99pgpgt View Post
    Fuses don't limit the power going to the item that is drawing the power.
  15. #15 Re: Aeroforce Issue - not really turning on....
    Jun 2010
    ontario
    okay, so this may be making it to turn off and on whenever?
  16. #16 Re: Aeroforce Issue - not really turning on....
    London Ont, Canada
    yup sounds about right.. told you to use a 10a!
  17. #17 Re: Aeroforce Issue - not really turning on....
    Ohio
    no.. that IS what is making it turn on and off. look at the back of the gauge also and see if the little red jumper ( fuse looking thing ) is in there still.
  18. #18 Re: Aeroforce Issue - not really turning on....
    London Ont, Canada
    theres no spot on the back of the gauge for a fuse.. theres only 1 connector, a hole, and 2 bolts.
  19. #19 Re: Aeroforce Issue - not really turning on....
    Jun 2010
    ontario
    nope, there is not spot to have that red jumper
    and Jordon, i must've been texting when you told me this lol my bad, okay so i am just going to run down, switch it over to the pgm fuse and give it a try to see if it resolves it, if so, it was a user error
  20. #20 Re: Aeroforce Issue - not really turning on....
    Jun 2010
    ontario
    no, if there was too much current running to the item thats drawing it, the fuse would pop (obviously depending on fuse amperage)
  1. Car not turning over...
    By Bogers04SS in forum General Tech Discussion
    Last Post: 09-05-2011, 11:04 PM
  2. Car wants to die while turning
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2011, 10:32 AM
  3. Air bag not turning on
    By izup69 in forum 04+ Specifics
    Last Post: 03-13-2011, 05:56 AM
  4. Turning a 01' SE into a GT
    By Dangerous313KidInAPrix in forum Visual/Body Modifications
    Last Post: 03-03-2009, 09:17 PM
  5. TCS not turning off
    By Keet04GTP in forum General Tech Discussion
    Last Post: 08-06-2008, 02:57 PM
