Thread: Help!! What HID relay do I need.
Results 1 to 6 of 6
  1. #1 Help!! What HID relay do I need.
    Dec 2011
    Muskegon, Michigan, United States
    I know this is probably a dumb question. But I purchased some halo HID projectors from eBay. The bulbs are 8000k. But what I don't know is what relay harnes i need. How can I tell what one I need. Can I look at my ballast? The add didn't give the information. Idk if I need H1,H9, etc... Please help
  2. #2 Re: Help!! What HID relay do I need.
    GTP Level Member buickman104's Avatar
    NYC
    First you need to find out what kit you ordered. If you have no idea what bulbs are getting with your kit then there is a good chance you are going to get a bulb that won't fit your housing.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: Help!! What HID relay do I need.
    Dec 2011
    8000K Slim Xenon HID Kit+04-08 Grand Prix Halo LED Smoke Projector Head Lights | eBay idk know for sure what kit this is. But that's the link for the one I bought. If someone can tell me what relay harness I need. I'd appreciate it greatly.
  4. #4 Re: Help!! What HID relay do I need.
    NYC
    Is your GP a 2004+ model? Also do you have Spyder projector headlights? In the auction they only show spyder headlights which use a different bulb from the stock housing. What do you have?
  5. #5 Re: Help!! What HID relay do I need.
    Dec 2011
    It is the newer model. And everything came with it. The bulbs were already installed into the housing. They are projectors.
  6. #6 Re: Help!! What HID relay do I need.
    SE Level Member BKA05GT's Avatar
    May 2008
    Grand Ledge, Mi
    on a side note, let me know when you figure out what you need, as I wanted to order these. Also throw some pics up if you don"t mind. Best of Luck!!!
  1. HID Relay
    By apierce1289 in forum Audio, Security & Visual Electronics
    Last Post: 04-24-2012, 11:07 PM
  2. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  3. so i need a relay.....
    By quadracer960 in forum Audio, Security & Visual Electronics
    Last Post: 07-04-2010, 10:14 AM
  4. HID relay help!!!
    By mzendano in forum Visual/Body Modifications
    Last Post: 10-29-2009, 11:47 AM
