Thread: Audio help and ? come one come all
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21 Re: Audio help and ? come one come all
    Yoga city
    ok everyone big three took care of any issue i had, still wanna go bigger battery up front since im running a stocker and there will be future upgrades. really the ground help up front, but then again i have data2 codes that lead me to grounds in the car.
  2. #22 Re: Audio help and ? come one come all
    Sep 2011
    Arkansas
    Check out XS Power for batteries... the S3400 is a direct replacement, and it's an awesome battery. For a more budget-friendly option, check out Shuriken. They're re-badged Kinetiks. Also, if there's an O'Reilly's near you, you can get a Superstart Extreme AGM. It's a re-badged Deka Intimidator.
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  3. #23 Re: Audio help and ? come one come all
    Yoga city
    i dont know about rebadged anything, u got technically specs on the units?
  4. #24 Re: Audio help and ? come one come all
    Northeast Ohio
    Quote Originally Posted by I800C0LLECT View Post
    Same as the above answer...
    We have an individual around here somewhere who has gone to international competition in his class and won. He uses a stock alternator and only a couple thousand watts. A good ground is the key. Also, the charging state of a battery is above ~12.6V. Therefore, as long as you're above that you aren't ever pulling from the battery unless your vehicle is off. That's why upgrading a battery or even adding one in line downstream really doesn't do anything to help the electrical state of the system...unless the vehicle is off.
    well to get the most power out of your amps i think most are around 14v IIRC and most comps are with cars off from what i been to and heard the guys i went through to get my equipment own the 3rd loudest van in the world called the ground pounder its ****in mad
  5. #25 Re: Audio help and ? come one come all
    Yoga city
    yeah our cars run at 14.xx but tend to dip into the 13's with the way the electrical is setup
  6. #26 Re: Audio help and ? come one come all
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    referring to me? i had a "HO" alt (stocks holding up about the same tbh) also had a g34 in the trunk tho 12v ftw...
    side note if your wired at 1ohm your not seeing one ohm due to impedance rise. IE I've wired to 1ohm for 2 years (different subs and boxes still 1ohm tho) and the lowest I've seen was 2ohm highest was ~3.1ohm i'm normally around the 2.33ohm. That's useful info for when burping but music your doing all sorts of different notes so the rise goes up and down depending on the tuning. Grounds are the key, bad ground more drop and sometimes allot of feedback. Just my 2c
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  7. #27 Re: Audio help and ? come one come all
    Yoga city
    Crazy my 2 re"s at the amp read 1.2 all day and I know my dmm is off so I'm at .9 or a true 1
  8. #28 Re: Audio help and ? come one come all
    Cedar Rapids, IA
    crazy try CLAMPING it then you take the same numbers and divide to get your ohm load.. IE last show (last one with the 1200D AQs) had clamped with 65.9V and 28.5A that's ruffly 1878W, @ 2.3Ohm originally wired to 1ohm
  9. #29 Re: Audio help and ? come one come all
    Yoga city
    no clamp just a cheap dmm, but i am loving it right now
  10. #30 Re: Audio help and ? come one come all
    Cedar Rapids, IA
    Facepalm need a clamp that hold max Amp and a DMM that holds Max volts
  11. #31 Re: Audio help and ? come one come all
    Sep 2011
    Arkansas
    Quote Originally Posted by Jteske88 View Post
    Nope, just that they're well-respected batteries in the audio community. Any and all technical specs can be obtained through google.
  12. #32 Re: Audio help and ? come one come all
    Cedar Rapids, IA
    Quote Originally Posted by Fatboy501 View Post
    XS Power by far is the best battery for audio.
  13. #33 Re: Audio help and ? come one come all
    Sep 2011
    Arkansas
    Quote Originally Posted by 1LoudGrandPrix View Post
    Agreed. I just offered the other options as they're lower-cost. I find that many people don't want to pay XS prices lol. XS is the shiznit though, no doubt about that.
  14. #34 Re: Audio help and ? come one come all
    Cedar Rapids, IA
    i being one of them i can get almost 3 dekkas for the price of a xs....
    to the OP take the muti meter to your battery write down the voltage, then goto your amp inputs do the same thing and post your results. Do it with car on and one with it off
  1. New audio setup! JL Audio
    By GP JLM in forum Audio, Security & Visual Electronics
    Last Post: 02-25-2011, 12:27 AM
  2. audio
    By 95granprix in forum Introductions/Noob Questions
    Last Post: 11-24-2009, 01:00 AM
  3. about car audio
    By tonyplo in forum Audio, Security & Visual Electronics
    Last Post: 10-20-2009, 03:56 PM
  4. Aux Audio
    By iflycessnas05 in forum Audio, Security & Visual Electronics
    Last Post: 06-20-2008, 06:28 PM
