Thread: Audio help and ? come one come all
Results 1 to 20 of 34
  1. #1 Re: Audio help and ? come one come all
    GTX Level Member cerick08GP's Avatar
    Quote Originally Posted by Jteske88 View Post
    and while runnign i noticed little clamp meter thing on the ground? whats that for? well anyone with some experince let me know. my car is a 05 gxp 5.3l,
    From personal experience the only thing you really need to know about that amp meter is if you run a ground wire to the battery negative terminal that wire must pass through the amp meter as well. Lets say you don’t do that, after a while (not immediately) you will get a “battery saver active” warning on your DIC. Don’t ask how I know that.
    Basically GM uses that amp meter to monitor the state of charge in the battery and adjusts alternator voltage in an attempt to keep the needs of the car meet while trying to maximize the life of the battery. If you bypass the amp meter the whole program eventually goes out of whack.
    Good luck beefing up your system man
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  2. #2 Re: Audio help and ? come one come all
    GTP Level Member
    springfield IL
    Op go back to the basics and check the wires and connects... Something isnt right... Alt mite be goin out or even the bat on its last leg!! Lol
  1. New audio setup! JL Audio
    By GP JLM in forum Audio, Security & Visual Electronics
    Last Post: 02-25-2011, 12:27 AM
  2. audio
    By 95granprix in forum Introductions/Noob Questions
    Last Post: 11-24-2009, 01:00 AM
  3. about car audio
    By tonyplo in forum Audio, Security & Visual Electronics
    Last Post: 10-20-2009, 03:56 PM
  4. Aux Audio
    By iflycessnas05 in forum Audio, Security & Visual Electronics
    Last Post: 06-20-2008, 06:28 PM
