Thread: REALLY Hot AMP
Results 1 to 20 of 30
  1. #1 REALLY Hot AMP
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    Ok here is the specs of my system in my car. I was wondering why my AMP would get so hot and stop working after having the music up? I mean the amp wont blow because it shuts itself off and these 3 lights on it will start blinking to avoid this. But to have the music blared up to what i want, i have to have ALL windows down so it can breathe so it doesnt shut itself off.
    The black sticker of course is the specs of my 12s. What should i do? Bigger AMP maybe? Im i pushing to much power? Can anyone give me any clues why my AMP gets so damn hot an shuts off? Id like to enjoy the music without having all windows down....
    By the way, i have the amp out in the back seat, this little compartment comes down in the middle in the back between both back seats....
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
  2. #2 Re: REALLY Hot AMP
    GTP Level Member
    Nov 2011
    Kansas
    well, your sub says 400 watts, and your amp says 250....... That may be a problem. However, if you dont have the amp tuned that can also cause major problems.
    What gauge wire you running to the amp from the battery? And what are your other specs? I am betting it isnt tuned properly and you are pushing that little amp too much for what you have sub wise.
  3. #3 Re: REALLY Hot AMP
    Well what IS the nominal load?
    Are you clipping the amp to all hell?
    Does the amp have any airflow?
    Is it class A? A/B? D? H?
  4. #4 Re: REALLY Hot AMP
    Houston
    Everybody that bought that package deal has the same issue. Sell the amp and get a larger amp to properly push the subs. Or for the time being, just turn the gain down.
  5. #5 Re: REALLY Hot AMP
    Jan 2012
    Sturgis, MI
    Ok guys, im a noobie to stereo systems but if it helps any, the X-over is switched to LPF. What other specific details do you guys want to know? Oh and my wire is an 8 guage wire!!!
    Miles: 170-XXX
    Engine: 3.8L V6
  6. #6 Re: REALLY Hot AMP
    GTP Level Member
    Nov 2011
    Kansas
    What is your gain set to on your amp??
  7. #7 Re: REALLY Hot AMP
    Jan 2012
    Sturgis, MI
    Quote Originally Posted by develand View Post
    The gain is up all the way...
    Miles: 170-XXX
    Engine: 3.8L V6
  8. #8 Re: REALLY Hot AMP
    GTP Level Member
    springfield IL
    Quote Originally Posted by Adidasdude1989 View Post
    PROBLEM!! the gain is NOT a volune knob... Live it learn it love it!! Haha
    Sell that krappy amp and buy a mmats... U can run those full tilt on 104* day and they will be warm if that!!! I personally think they are the ultimate daily amp. They just run soooooo dammn cool!
  9. #9 Re: REALLY Hot AMP
    GTP Level Member
    Nov 2011
    Kansas
    That is part of your problem. You are pushing your amp too hard. Back it off some. I dont think mine is above like 60% and I have 2 10's. All the way up doesnt mean the best sound quality.
  10. #10 Re: REALLY Hot AMP
    Matched to output level of deck and done.
  11. #11 Re: REALLY Hot AMP
    Jan 2012
    Sturgis, MI
    It turns down bass power right?
    Miles: 170-XXX
    Engine: 3.8L V6
  12. #12 Re: REALLY Hot AMP
    no.
    it turns the gain down.
    which is not volume.
  13. #13 Re: REALLY Hot AMP
    GTP Level Member
    Nov 2011
    Kansas
    It can affect bass power. But obviously you are over powering your sub.
    My amp is on the back of the seat with the sub box right near it. And I have never overheated. You are pushing your system too hard.
  14. #14 Re: REALLY Hot AMP
    Yes. But obviously you are over powering your sub.
    No to the first bit. If anything he doesnt have enough amp for the subs.
    He's pushing the amp too hard.
  15. #15 Re: REALLY Hot AMP
    GTP Level Member
    Nov 2011
    Kansas
    I edited it.. But that is pretty much what I was getting at.
  16. #16 Re: REALLY Hot AMP
    Apr 2012
    nova
    I'm gonna go in a different direction
    You said 2 12's? How do you have them wired? If you have them in parellel and your spec sheet says 2 ohms that means the amp is seeing 1ohm, and clearly it can't handle one ohm
    1999 gtp coupe... P&P heads, lim, and sc, comp vs cam, intake, dp and ubend
    2003 ford ranger fx4 level II- twin stick
  17. #17 Re: REALLY Hot AMP
    Houston
    Quote Originally Posted by bigburban View Post
    No. His subs are wired to 2 ohm. He bought a package deal that comes with 2 single 4ohm coil subs, the enclosure and an amp that cannot push the subs. Everybody that buys this package deal has to crank their gain all the way up to hear a little bit of bass. He needs a bigger amp. MTX and Alpine both do this crap (sell a package deal with a weak amp). I dont understand the reasoning behind it.
  18. #18 Re: REALLY Hot AMP
    Jan 2012
    Sturgis, MI
    An see thats what i thought when i bought the bundle but it was around my budget area so i went for it...Now will a simple video help you guys out on how everything is wired? I can do that if need be...
    Yeah i feel as if the amp is getting so hot, im pushing so much power to it so it kicks off...Just right now my budget is tight and i love bass but im sick of this thing cuttin down on me:/
    Miles: 170-XXX
    Engine: 3.8L V6
  19. #19 Re: REALLY Hot AMP
    Houston
    No, its easy to understand how they're wired. Both subs are just paralleled to a 2ohm load. One thing you could do, for the time being, is a sub delete. Just unscrew a sub and unhook it, and screw it back in. Turn your gain down on the amp and blast away. I bet it will sound louder with just one and the amp should remain cool.
  20. #20 Re: REALLY Hot AMP
    Jan 2012
    Sturgis, MI
    Ok point me to the right direction for a different amp that i can use both of my subs for, i love strong bass and nothing feels better but your ears rattling This does is but barely long enough, i do love my A/C on hot days but air cant reach the amp unless its the air from driving down the road....ANNOYING TO DEAL WITH!!!!
    Miles: 170-XXX
    Engine: 3.8L V6
amp, hot
