Thread: Grounding points // Voltage Drops...
Results 1 to 11 of 11
Toofastgs Grounding points // Voltage... 09-05-2008, 05:47 PM
BADAZGTP Re: Grounding points //... 09-05-2008, 07:31 PM
JCG\'s-GTP Re: Grounding points //... 09-05-2008, 07:52 PM
gtpinsc Re: Grounding points //... 09-08-2008, 09:07 PM
offroadfury6 Re: Grounding points //... 09-08-2008, 01:01 PM
BADAZGTP Re: Grounding points //... 09-08-2008, 09:09 PM
gtpinsc Re: Grounding points //... 09-08-2008, 09:25 PM
BADAZGTP Re: Grounding points //... 09-08-2008, 09:38 PM
gtpinsc Re: Grounding points //... 09-08-2008, 10:00 PM
VinnieGTP Re: Grounding points //... 09-08-2008, 11:05 PM
JCG\'s-GTP Re: Grounding points //... 09-09-2008, 09:21 PM
  1. #1 Grounding points // Voltage Drops...
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    You guys with multi amp set ups. Where is your earth ground at?
    Mine is on the inner spare tire well. Cleaned with a air grinder with steel brush. 4AWG to a ground Distribution block less then 2' away.
    Right now for some reason im losing voltage to my amps.
    Alt i am seeing 14.3-14.4 Volts
    Batt im seeing 14.2-14.3
    ANL Fuse holder W/display 13.9-14.1 even on output with DMM
    Cap input 13.9-14.00
    Power block 12.5
    Power at amps 10.9-11.3
    I know this has to do with grounding. Any help? Any better grounding points in trunk?
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  2. #2 Re: Grounding points // Voltage Drops...
    Apr 2008
    Chillin at the Beach , VA
    I ground mine on the passenger side strut tower, but side shouldn't matter. What size are the amps and what guage power and ground wire are you using?
  3. #3 Re: Grounding points // Voltage Drops...
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    What kinda wire are you using and is it all the same from battery to amp? Reason I ask is some cheap 4ga has the diameter of 4ga but inside the jacket the wire is about 8ga. Either way mine is grounded to strut tower
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  4. #4 Re: Grounding points // Voltage Drops...
    Jul 2008
    sumter,south carolina
    Quote Originally Posted by BADAZGTP View Post
    me too...never had power loss or feedback problem... 4 gauge stinger wires
  5. #5 Re: Grounding points // Voltage Drops...
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    i folded down my seats and took out a bolt that holds the frame...granded it on there but I gotta self-tap me a screw on the top of the metal in my trunk...i dont like where it's grounded at now, scared it'll come loose...
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  6. #6 Re: Grounding points // Voltage Drops...
    Apr 2008
    Yea, the only problem I am having is the dimming lights. Gotta get me a cap. Pushing 2300 watts doesn't help.
  7. #7 Re: Grounding points // Voltage Drops...
    Jul 2008
    ur gonna b deaf one day ...800 watts total is enuff for me
  8. #8 Re: Grounding points // Voltage Drops...
    Apr 2008
    What? I have a 800 on my mids and highs and a 1500 on the two 12" subs. Used to run about 3500 watts and 3 15's in her a couple years back.
  9. #9 Re: Grounding points // Voltage Drops...
    Jul 2008
    yep and ill b able to hear when im 60 i got a 500 watt memphis class d on my 2 10's (digital dynamics) and 300 watt memphis on hi's mid's that hurts my ears at times.
  10. #10 Re: Grounding points // Voltage Drops...
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    It sounds like you bought "tinned" wire. Cheap wire is covered in tin to get larger gauge out of less copper.
    1/0ga from battery to the distro block FTW!
  11. #11 Re: Grounding points // Voltage Drops...
    Feb 2008
    Nashville
    I agree with Vinnie
  1. Shift points
    By TDCRacing in forum General Tech Discussion
    Last Post: 05-28-2008, 02:26 PM
  2. Replies: 5
    Last Post: 05-12-2008, 01:51 AM
  3. Reputation points?
    By GreenNirvana101 in forum Off Topic Discussion
    Last Post: 04-15-2008, 05:29 PM
  4. Alternator Voltage booster gone wrong
    Last Post: 03-19-2008, 03:44 PM
  5. WOT Shift Points...RPM/MPH
    By japslpr in forum PCM Tuning
    Last Post: 02-04-2008, 07:12 PM
