Thread: trunck rattles from subs
Results 1 to 17 of 17
  1. #1 trunck rattles from subs
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    how do i stop it? the cheapest way would be appreciated thanks
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: trunck rattles from subs
    The Boss Iceman6669's Avatar
    Jun 2011
    Cheap leftover carpet pieces..... That is the cheapest
    2011 F-150 Yote powered
  3. #3 Re: trunck rattles from subs
    Omaha, NE
    Weld the trunck shut. Cheap and effective.
  4. #4 Re: trunck rattles from subs
    Houston
    Build a wall to block the most of the vibrations from reaching the trunk lid. Total cost, maybe $15
  5. #5 Re: trunck rattles from subs
    Oct 2011
    Michigan
    where would i put the carpet? and cant build a wall someteims the subs need to come out
  6. #6 Re: trunck rattles from subs
    SMGPFC Member #10
  7. #7 Re: trunck rattles from subs
    Oct 2011
    Michigan
    ^^ what.....? i just spray the inside of my trunk deck with that stuff and it wont rattle?
  8. #8 Re: trunck rattles from subs
    Sep 2011
    Arkansas
    Stopping trunk lid rattle can be somewhat of a pain. Your best bet is going to be adding mass, which would by using a product such as Audio Technix Sound Deadener - Better than Dynamat - Home offers. Using great stuff in the gaps between the braces and trunk panel itself helps as well, but I haven't noticed a lot of room to do that in my car. In all honesty, it's going to rattle (edit: It's going to flex) on low notes, assuming you have a somewhat potent setup. Mine actually makes a strange squeaking sound on the lowest ones lol. Oh... tighten your spoiler bolts too. Get in the habit of checking those every other week or so. Helps a ton. It's fun when your whole back end moves as much as the trunk does
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
    Dec 2010
    DMV
    Hey you got a write up for the wall?
    Looks nice and neat
  10. #10 Re: trunck rattles from subs
    Houston
    Looks nice and neat
    Theres really no write up needed. I just made a stencil out of cardboard and trimmed the MDF to match. The main purpose behind it was to hide the subs. But it turned out to be quite a rattle blocker.
  11. #11 Re: trunck rattles from subs
    Acworth, Georgia
    That wall you made. Your subs are still facing out? I was thinking of doing that but maybe facing my subs in and possibly adding a port hole. I have a non ported box for my 15's and I'm thinking of new ideas. Any help?
  12. #12 Re: trunck rattles from subs
    Sep 2011
    Arkansas
    2 15's ported is not going to fit behind that wall... not in any proper airspace. In fact, you won't be fitting 2 ported 15s in a 97-03 trunk in proper airspace without building in the trunk.
  13. #13 Re: trunck rattles from subs
    Oct 2011
    Michigan
    i barley fit two ported 12's it takes up have the trunk
  14. #14 Re: trunck rattles from subs
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    tried the 15s can't be done right enough to over power 2 12s in a proper box (2 15s 142.7db.. 2 12s 145.6db same power)
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  15. #15 Re: trunck rattles from subs
    Acworth, Georgia
    So what would you guys suggest I do? I have those two infinity 15s and a kenwood 12 that I had for a few weeks in the car. I'm all for building a custom box. Would one 15 in a custom ported box be my best bet?
  16. #16 Re: trunck rattles from subs
    make it curve with the 15's on the outside and the 12 in the middle
    SMGPFC Member #10
  17. #17 Re: trunck rattles from subs
    Cedar Rapids, IA
    that sir would sound like ass
    just a single 15 custom ported box in the low 30s
  1. Random Rattles
    By BOOST in forum The Rant Forum
    Last Post: 06-29-2011, 10:17 AM
  2. My rearview mirror rattles like a pop can with subs
    By MattTheBaker123 in forum Visual/Body Modifications
    Last Post: 12-14-2010, 07:51 PM
  3. Stock 6x9 rattles... *Added info + new goal, need help*
    By nik12937 in forum Audio, Security & Visual Electronics
    Last Post: 10-25-2010, 08:46 PM
  4. How to diagnose front suspension rattles?
    By PCweber in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 08:41 AM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
