Thread: Need some help...
Results 1 to 18 of 18
  1. #1 Need some help...
    Milwaukee
    So I figured that this falls in this area of the forums since it deals with lighting, if not feel free to move it. Here's the issue;
    Interior lights won't shut off even in drive and will only turn off after like 10 minutes of the car being closed/locked. Fuse is pulled to save my battery.
    -No "door ajar" lights on the DIC
    -Dimmer switch was not left on, and I replaced the headlight/dimmer switch with no luck
    -Unplugged door jamb switch and no luck
    -Seems like it's related to the driver door but again, no luck with the door jamb switch unplugged.
    Any thought/info/advice is appreciated!
  2. #2 Re: Need some help...
    Jan 2012
    Philadelphia
    not too sure, someone else on here might know id wire your own switch for now till you figure it out that mights help so you'll still have interior lights
  3. #3 Re: Need some help...
    Any one of about five different triggers could be at fault, or the remote module might be telling it to stay on. Need an FSM to track them all down.
  4. #4 Re: Need some help...
    Apr 2009
    Fort Worth TX
    Good luck.
  5. #5 Re: Need some help...
    Chuck... need a schematic for the triggers is what i was wink wink eluding to... wink wink, wonder who seems to always have the schematics wink wink handy.... cough cough.. BTW need a schematic in the 03 with trouble post too.
  6. #6 Re: Need some help...
    Apr 2009
    Fort Worth TX
    Let me check on this one first.
    Wait, what year is this?..I mean the car. HaHa
  7. #7 Re: Need some help...
    Your falling behind buddy... c'mon let's step it up.
  8. #8 Re: Need some help...
    Apr 2009
    Fort Worth TX
    I can't get the interior schematics right now.
  9. #9 Re: Need some help...
    Ok, I'll start drawing them on a paper from memory. Heck..i probably know them well enough...
  10. #10 Re: Need some help...
    Apr 2009
    Fort Worth TX
    It looks like the problem may be the BCM.
    2001 try this:
  11. #11 Re: Need some help...
    Apr 2009
    Fort Worth TX
    More schematics:
  12. #12 Re: Need some help...
    Apr 2009
    Fort Worth TX
    And more:
  13. #13 Re: Need some help...
    Apr 2009
    Fort Worth TX
    And more:
  14. #14 Re: Need some help...
    Apr 2009
    Fort Worth TX
    Door open switches:
  15. #15 Re: Need some help...
    Apr 2009
    Fort Worth TX
    Roof lamp:
  16. #16 Re: Need some help...
    Apr 2009
    Fort Worth TX
    Switches:
  17. #17 Re: Need some help...
    I see a little egging on produces serious results.
  18. #18 Re: Need some help...
    Apr 2009
    Fort Worth TX
    There's actually a lot more. Let me know if this doesn't do it. Heck, I can use these myself. When it comes to cars, I've always used the trace/guess method until I finally give up.
