Thread: how to tune an amplifier??
Results 1 to 20 of 39
  1. #1 how to tune an amplifier??
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    i am so confused on how to tune my amplifier using a digital multi meter?
    i am using a hifonics brutus 1200 amplifier
    the settings it has are "level" (which i think you are supposed to match to the output voltage of your head unit) "phase" "remote" (wired to a remote box in the front of the car that goes from max to min) "bass eq" "sub sonic" and "low pass"
    i looked in my head units owners manual and it says "preout maximum output level 2.0v" so im guessing that i set the level to 2.0v but im not sure how you do this when its on a dial from .02v to 9v
    if there is any other info you need i will do my best to give it to you
    thanks for the help!
  2. #2 Re: how to tune an amplifier??
    Sep 2011
    Arkansas
    How To: Set your Amplifier Gain - SSA Car Audio Forum
    As for your Sub Sonic filter, what kind of enclosure do you have? If ported, a lot of people recommend setting it a little bit under tuning... for instance, if your enclosure is tuned to 35hz then set the SSF @ 30hz. If sealed, most people just leave it off, or turned to the lowest setting. I leave mine off period, because music I play tends to dip rather low. As for bass knobs... I usually just leave them unhooked. Phase is referring to your + and -.... sometimes people reverse the polarity to help the subs response if it seems slightly behind the rest of the music... some headunits can control this as well. It's sometimes used as a bootleg time-alignment. Low pass is your low-pass filter... basically whatever you set that at, frequencies lower than that will be passed on the the subwoofer. I usually set mine around 60hz, but some people like their subs to play higher than that.
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  3. #3 Re: how to tune an amplifier??
    Nov 2011
    Decatur
    so should i just leave phase on 0 degrees? and sub sonic to 15hz? (knob goes between 15-35hz)
  4. #4 Re: how to tune an amplifier??
    Sep 2011
    Arkansas
    What kind of box are you using? Sealed, ported, bandpass? If ported, what is the enclosure tuned to? What sub? What kind of music do you primarily listen to? Yes, you can leave phase on 0.
  5. #5 Re: how to tune an amplifier??
    Nov 2011
    Decatur
    okay so for the gains, each one of my subs ( i have dual 12's) is 50-150 rms. so since the amp goes up to like 900x1 at two ohms so thats what 450 to each speaker? i should use the speaker rms for my calculations so i dont over power them?
  6. #6 Re: how to tune an amplifier??
    Feb 2009
    Virginia
    Graphing Trig Functions: Phase Shift
    When people are changing phase they are trying to align the amplitudes of the signal. When two signals(two speakers) are 180 degrees out of phase with each other they cancel each other out. Therefore you flip polarity to reverse the amplitude/align the phase. Reversing polarity is a elementary way of doing that. Because it flips the amplitude of the signal that means it delays the signal by half the phase length adding a rudimentary time delay.
    Because each frequency has it's own wave length phase and shift are not even across the board. You're typically only aligning one frequency.
    11 is louder than 10!
  7. #7 Re: how to tune an amplifier??
    Sep 2011
    Arkansas
    Yes, using your speakers' RMS would be the correct way for you to do this.
  8. #8 Re: how to tune an amplifier??
    Sep 2011
    Arkansas
    Quote Originally Posted by I800C0LLECT View Post
    Lol yeah that... I just call it bootleg time alignment lol.
  9. #9 Re: how to tune an amplifier??
    Nov 2011
    Decatur
    Quote Originally Posted by Fatboy501 View Post
    i have a sealed box. both subs are 4 ohm SVC rated at 50-150 RMS 800 MAX. i primarily listen to rap
  10. #10 Re: how to tune an amplifier??
    Sep 2011
    Arkansas
    Well, yes, you can leave the SSF at 15... but, idk, with Dual subs, I'd set it right under 30ish Hz just to be safe.
  11. #11 Re: how to tune an amplifier??
    Nov 2011
    Decatur
    i thought you said with sealed box you should just leave it all the way down or off?
  12. #12 Re: how to tune an amplifier??
    Feb 2009
    Virginia
    Quote Originally Posted by 2dee11 View Post
    True...sealed will have a roll off and it wouldn't matter in majority of cases. You usually want to add a filter if you're attempting to use EQ to boost the lower end of the sub output and I would suggest putting the infrasonic filter at just below the Fs of the speaker and hopefully it's a 24 decibel slope
  13. #13 Re: how to tune an amplifier??
    Sep 2011
    Arkansas
    I did, and you absolutely can, but I don't know how much low-note abuse those Duals are going to take as I've never messed with them. Besides, I doubt anything you play will go much below 28hz, which is was the low note in "Put On" is if the song is not altered.
    EDIT: What he said. I just tend to be very careful with other people's equipment when recommending settings, and I've honestly never used a Dual subwoofer.
  14. #14 Re: how to tune an amplifier??
    Nov 2011
    Decatur
    so should i put it to 30ish?
  15. #15 Re: how to tune an amplifier??
    Sep 2011
    Arkansas
    I would... but I800 knows a lot more about sealed enclosures than myself... so... yeah go with him on this one.
  16. #16 Re: how to tune an amplifier??
    Feb 2009
    Virginia
    Fatboy knows more than I do about subs...I won't be shy I say put it on 30hz until you know what the Fs of the T/s parameters tell you
  17. #17 Re: how to tune an amplifier??
    Nov 2011
    Decatur
    Voltage of the output = sqrt(RMS Power X impedance of the speaker)
    • Example
      Say the amp provides 100WRMS into a 4 ohm speaker:
      Voltage = sqrt(100W X 4 ohms)
      Voltage = sqrt(400W*ohms)
      Voltage = 20V
    am i doing this correctly??
    Speakers are 150 RMS a piece so 150x2 is 300 and they are 4 ohm speakers:
    Voltage = sqrt(300W X 4 ohms)
    Voltage = sqrt(1200W*ohms)
    Voltage = 34.64101615137755 V
    or should i do 2 ohms because its a mono amp and they are wired as such
    this is also confusing because the amp instructions says to match the radio output sensitivity for the level and my radios maual says 2.0v is its output
  18. #18 Re: how to tune an amplifier??
    Feb 2009
    Virginia
    I thought you were supposed to supply a set frequency/sine wave to the amplifier when you're measuring signal strength? Then you set the gain according to that? i.e. volume knob at ~80% with a 100hz sine wave. Use your DMM and the rest is math and gain knob?
    EDIT: http://www.jlaudio.com/header/Suppor...Setting/287546
    I know fatboy gave a link but sometimes different pictures make things click for different people
  19. #19 Re: how to tune an amplifier??
    Sep 2011
    Arkansas
    Nvm, just read the above post.
  20. #20 Re: how to tune an amplifier??
    Feb 2009
    Virginia
    my bad fatboy....everything you said was spot on...wasn't trying to steal any thunder
  1. How-to add LED's & have them pulse from amplifier
    By mousemonster1232 in forum How To Write-Ups/Tech Tips
    Last Post: 03-17-2011, 06:46 PM
  2. Help on choosing new amplifier
    By GAFF in forum Audio, Security & Visual Electronics
    Last Post: 03-04-2010, 09:39 AM
  3. How to install Amplifier
    By mainecrab in forum Audio, Security & Visual Electronics
    Last Post: 10-28-2009, 08:48 PM
