Thread: how to tune an amplifier??
Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
  1. #21 Re: how to tune an amplifier??
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    i have no idea, thats why i am asking you guys, lol this is what it says
    Level (GAIN) Control Setup:
    Ensure that the Level is turned completely to the left prior to turning the system on. Next you should insert a CD or cassette that you are familiar with
    to use as a reference, and turn the head unit volume control to about 80% of its full setting. The system sound level will of course be very low, and
    the following procedures will help you to match the amplifier input sensitivities properly to the head unit output signal level.
    It is important to match the amplifier
    LEVEL input sensitivity to the Radio/CD output sensitivity. This can be located in the Radio/CD manual.
    If the Radio/CD output sensitivity is 2 volts, then adjust the amplifier
    LEVEL input to 2 volts.
    If you are not sure what the Radio output sensitivity is, follow these general guide lines:
    Turn the level control up slowly, till you hear distortion, then back off a few degrees on the control. If at any point your amplifier goes into protection,
    you will need to turn the Level to the left a bit and then try again. If you reach a point where the output does not increase, stop turning the Level
    control to the right as the amplifier/subwoofer combo has reached its maxx output in this application.
  2. #22 Re: how to tune an amplifier??
    Sep 2011
    Arkansas
    Nah it's good.. we're saying the same things... we just speak slightly different languages. In any case, we'll get ole' Dee where he needs to be lol.
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  3. #23 Re: how to tune an amplifier??
    Nov 2011
    Decatur
    Quote Originally Posted by Fatboy501 View Post
    you can just call me devin lol but yes thank you guys very much this is all so confusing to me as everything says something different
  4. #24 Re: how to tune an amplifier??
    Sep 2011
    Arkansas
    Yeah man, just download some test tones and use the DMM tutorials... you can pretty much ignore the "Back it off once you hear distortion" crap. As for your headunit volume... different ones clip at different levels. Honestly, 3/4 of the way up actually is somewhat useful in this scenario... you're saying your h/u has 2 volt pre-outs, so I'm assuming it's a lower level one like mine. Mine's a Pioneer deh-3200ub, and I never go above 53...
  5. #25 Re: how to tune an amplifier??
    Nov 2011
    Decatur
    my head unit is the pioneer avh-p1400dvd
  6. #26 Re: how to tune an amplifier??
    Sep 2011
    Arkansas
    Ok, so yeah, 50-55 should work out well for choosing your max volume. Most a/v headunits don't have great pre-out voltage. So, get your tones, set your volume, and have at it.
  7. #27 Re: how to tune an amplifier??
    Nov 2011
    Decatur
    so i turn all my settings on my head unit to 0. get a test tone (what test tone should i use??) play it thru the head unit. unplug the speakers. stick the dmm in the positive and negative turn it to ac and tune till i get desired voltage?? is this correct?
    im still confused on what my desired voltage is and what tone i should use?
  8. #28 Re: how to tune an amplifier??
    Nov 2011
    Decatur
    i think youre talking about the volume level on the head unit?? mine goes from 0-40 so 75% would be 30 and i usually have it at about 25
  9. #29 Re: how to tune an amplifier??
    Sep 2011
    Arkansas
    Your desired voltage is the one from the equation you did earlier. Use a 50hz test tone.
  10. #30 Re: how to tune an amplifier??
    Sep 2011
    Arkansas
    Quote Originally Posted by 2dee11 View Post
    Ah ok, I figured since it was Pioneer it'd be like mine... guess the a/v units are a lot different. Well, yes, you're good with your levels then. As long as you don't just crank it and wonder what happened when stuff goes *poof* lol.
  11. #31 Re: how to tune an amplifier??
    Sep 2011
    Arkansas
    As for the settings on the h/u... I always, always, always leave mine on "flat", but I also have an amplifier for my mids/highs. Set your subwoofer level on the headunit to the highest you'll ever have it... honestly, leaving it at 0 (if it goes down into the negative numbers) will work just fine. Some headunits don't put out any decent voltage from their sub pre-outs until the subwoofer level is up though... in your case, I'm honestly not sure, so I'd use it with it at 0.
  12. #32 Re: how to tune an amplifier??
    Nov 2011
    Decatur
    did i do the equation correctly? i wasnt sure if i should multiply by 2 or 4 ohms
  13. #33 Re: how to tune an amplifier??
    Sep 2011
    Arkansas
    Do it by the final load the amp will be seeing... so use 2 ohms.
  14. #34 Re: how to tune an amplifier??
    Nov 2011
    Decatur
    sooo
    Voltage = sqrt(300W X 2 ohms)
    Voltage = sqrt(600W*ohms)
    Voltage = 24.49489742783178 V
  15. #35 Re: how to tune an amplifier??
    Sep 2011
    Arkansas
    I believe you're spot-on. Just use 24.5 volts obviously though lol.
  16. #36 Re: how to tune an amplifier??
    Nov 2011
    Decatur
    haha thanks. i really appreciate it!!
  17. #37 Re: how to tune an amplifier??
    Nov 2011
    Decatur
    when i tune it should i have the remote knob on max or min??
  18. #38 Re: how to tune an amplifier??
    Houston
    Do you have subwoofer control on your HU? If so, I wouldnt use a bass (gain) knob .
  19. #39 Re: how to tune an amplifier??
    Northeast Ohio
    with the gain know you want to set them in relation to the pre-outs on your head unit and depending on the amp you normally and ohm your running it at will decide what gain you should run at.....gain is just telling the amp what kind of signal is going to receive too much gain(telling the amp is going to get more power then it actually does) is no good same is not enough i would start around .5v-1v....once you set it dont touch it again and control the subs through your head unit
  1. How-to add LED's & have them pulse from amplifier
    By mousemonster1232 in forum How To Write-Ups/Tech Tips
    Last Post: 03-17-2011, 06:46 PM
  2. Help on choosing new amplifier
    By GAFF in forum Audio, Security & Visual Electronics
    Last Post: 03-04-2010, 09:39 AM
  3. How to install Amplifier
    By mainecrab in forum Audio, Security & Visual Electronics
    Last Post: 10-28-2009, 08:48 PM
