Thread: Where to Mount my Amp?
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: Where to Mount my Amp?
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Quote Originally Posted by 2dee11 View Post
    yeah chamilton if i could do my system exactly like that i would, that absolutely sick!! cept id change the miami logo :P what to? no idea maybe the pontiac symbol? i dunnoo..
    but yes i am about to hook up the amp as im posting this.. here it goes!
    Just make sure everything is off before you hook everything up, and then only fire it up when your amplifier is fully installed!
    Infinity all around.
  2. #22 Re: Where to Mount my Amp?
    Sep 2011
    Arkansas
    Play it all the way safe... disconnect the negative terminal from the battery. Just remember your radio settings lol.
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  3. #23 Re: Where to Mount my Amp?
    Nov 2011
    NY
    Quote Originally Posted by chamilton89 View Post
    That's one seriously sick trunk space!
    Niceeeee!
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    Quote Originally Posted by coolone View Post
    Niceeeee!
    X's 2
    Sent from my Motorola ATRIX 2 on tapatalk
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  5. #25 Re: Where to Mount my Amp?
    Quote Originally Posted by dazedandconfused View Post
    X's 2
    Thanks guys, I really appreciate it. If you want to see more about the build, it can be found here:
    http://www.grandprixforums.net/trunk...all-47509.html
    Id ont mean to thread highjack so, if you want to talk about it or have any questions, lets do it there!
  6. #26 Re: Where to Mount my Amp?
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    alright well the guy (a friend of my mom and i's) who was supposed to come help me hook up the amp today had to work overtime at work so i prolly wont get it fully installed till this weekend. i would do it myself but my mom wants someone to watch over me and make sure i do it all the right way and what not, which isnt totally a bad idea. but whenever we hooked up my new head unit this past weekend he just sat there and watched me do it all... lol. but i did get the amp mounted. but the first time was an epic FAIL.. ill have some pics tomorrow or somethin but i didnt think to test it out when the seat was up and it hit the diagonal corner. *facepalm* so i had to move the amp and drill new holes, the old holes arent too terribly noticeble but i figured you guys would get a good laugh
  7. #27 Re: Where to Mount my Amp?
    Sep 2011
    Arkansas
    Man, that's a small blunder lol... it's very funny watching someone build a speaker box after measuring incorrectly and attempting to literally drop-kick it into their trunk lmmfao. In any case, good thing you've got it mounted... one step closer to some bass!
  8. #28 Re: Where to Mount my Amp?
    Nov 2011
    Decatur
    do you guys have any good suggestions on where to ground?
  9. #29 Re: Where to Mount my Amp?
    Jun 2011
    Detroit, MI
    If its in the trunk, by the strut mounts I think is the best.
    iLoveSpade
  10. #30 Re: Where to Mount my Amp?
    Houston
    The strut tower is good if your amp is close to it. You want your ground as short as possible. Make sure to clean off any paint before bolting in the ground wire. (Also make sure your ground is as big or bigger than your power wire **important**)
  11. #31 Re: Where to Mount my Amp?
    Nov 2011
    Decatur
    yeah my ground and power wire are the same size. but i was thinking about using a bolt thats under the back seat in 04+s around the middle ill post a picture hold on
  12. #32 Re: Where to Mount my Amp?
    Houston
    Anything that bolts to the body will work, unless you plan on running some cray power. Then you will want to go to the frame. Just make sure to remove the paint under that bolt.
  13. #33 Re: Where to Mount my Amp?
    Nov 2011
    Decatur
    awesome thanks
  14. #34 Re: Where to Mount my Amp?
    Nov 2011
    Decatur
    pics of my amp fail
    amp at night
    so i got my subs and their enclosures from a friend for free a while back... after finally getting them hooked up and using them for less than a week... i rattled that back off... it was only being held in by like two screws who's holes were like stripped... so i popped some of my own screws into until i build a custom enclosure
    ANYONE READING THIS LATER: MAKE SURE YOUR AMP WILL FIT WHEN YOU FOLD THE SEAT UP BEFORE SCREWING IT IN!!!
  15. #35 Re: Where to Mount my Amp?
    GT Level Member papaspanky's Avatar
    Jul 2010
    new england
    I murdered an Alpine 3555 cause I had it mounted on my sub box.
    81 T/A pure Pontiac 350,700r4 3.23's coming soon pure Pontiac 462 06 gt wizaird,XS power Headers,zzp ss ic,overkill tune 180 stat autolite 104's, 3.6 pulley.Special Edition HORNY DRIVER mod.
  1. Do you think this mount is bad?
    By davidw in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2012, 02:40 PM
  2. What mount should I get first?
    By kyle91 in forum General Tech Discussion
    Last Post: 07-26-2011, 01:51 PM
  3. Multikit/Mount Kit to mount EQ?
    By iceman977th in forum Audio, Security & Visual Electronics
    Last Post: 03-25-2011, 01:59 AM
  4. mount gps
    By macey43 in forum Audio, Security & Visual Electronics
    Last Post: 12-22-2010, 09:42 PM
  5. How did you mount your SD lip?
    By machinegunsquid in forum Visual/Body Modifications
    Last Post: 10-05-2010, 07:54 PM
