Did you ever figure this out? I put a HUD in my 06 GT and there was a wiring connector for the projector tucked up behind the gauge cluster, if you pull the cluster you should find it taped in the area where the projector mounts, if that makes sense. The switch wiring is plug and play too....good luck!
