Thread: post up your audio equipment
Page 32 of 36 FirstFirst ... 223031323334 ... LastLast
Results 621 to 640 of 707
  1. #621 Re: post up your audio equipment
    May 2014
    Flint
    That kinda helps my issue is on the passenger side the boot lines up with the dash so idk how it would be possible to wire through
  2. #622 Re: post up your audio equipment
    take the glove box out. or feed the wire in from the outside hole, you'll need to think on your feet here.
  3. #623 Re: post up your audio equipment
    GT Level Member chrishova's Avatar
    Norfolk, Virginia, United States
    American Bass 1100.1.... 12,500w RMS and two AB SQ925's
    https://fbcdn-sphotos-d-a.akamaihd.n...76e01b8fb6ce4e
  4. #624 Re: post up your audio equipment
    Sep 2011
    Copperas Cove, TEXAS
    Quote Originally Posted by chrishova View Post
    Holy fvckin amp Chris. Is that thing a 2 man lift!!!
  5. #625 Re: post up your audio equipment
    Yeah, kinda, except I did install it all alone, lol
  6. #626 Re: post up your audio equipment
    Nov 2014
    Oregon
    Would http://wwv.crutchfield.com/p_113DNN7....html?tp=20212 fit the 2007 GT?
    It is double din - additionally, any of you guys have this or a similar? How is it?
  7. #627 Re: post up your audio equipment
    Buffalo
    SEVEN 140ah batts, a XS Power D3400 up front, 4 runs of 1/0 and a Mean Machine 300a alt with external regulator
    i want to see a side profile shot of this car .... No way the rear end don't sag lol couldn't imagine the wheelies it does on take-off!
  8. #628 Re: post up your audio equipment
    I live here. DirtDog's Avatar
    Jun 2012
    **** I wanna know how much money he has in 0 gauge wire. At least 200
  9. #629 Re: post up your audio equipment
    No sag! Custom 1450 lb coilovers
  10. #630 Re: post up your audio equipment
    Sep 2011
    Yup, Chris don't fvck around when it comes to audio stuff in his GP.
  11. #631 Re: post up your audio equipment
    Buffalo
    Damn.... Dude that's fantastic !
  12. #632 Re: post up your audio equipment
    Jun 2012
    Alright audio guys. Questions. So I moved my battery to my trunk awhile ago. But I'm redoing all the wiring now and adding inline fuses. Should I just put 1 inline fuse on the ground from battery to chassis or one line fuse on positive near battery and one under hood on the other end of the wiring.
    Basically how and where should I install my fuses.
  13. #633 Re: post up your audio equipment
    Why would you put a fuse in the ground? Put a fuse between battery positive and whatever it goes to.
  14. #634 Re: post up your audio equipment
    Jun 2012
    Here's my thinking. So positive wire runs to starter. With engine running there would be electricity flowing both ways. So would I need two fuses. One near starter end and one in trunk with battery.
  15. #635 Re: post up your audio equipment
    Dafuq did I just read? Cars run on DC. DC only allows current in one direction.
    I'm sorry I just can't stop laughing.
  16. #636 Re: post up your audio equipment
    Jun 2012
    Lol. I'll try to explain better. If my positive wire running to starter gets a short and fuse pops wouldn't it continue to short out from starter side of the system. Being battery would be safe from fuse popping but current would still be flowing from alternator.
  17. #637 Re: post up your audio equipment
    A short wouldn't cause a fuse to pop, it would cause you to loose power along where the short is. An open would pop a fuse though. That is why the alt goes into the fuse box.
  18. #638 Re: post up your audio equipment
    Jun 2012
    So one fuse just on positive at battery I should be fine. I just don't want to have an electrical issue later on.
  19. #639 Re: post up your audio equipment
    Jun 2012
    Being if it shorts out between fuse and starter it would still pop the fuse but have current from alt
  20. #640 Re: post up your audio equipment
    Okay let us back the truck up here, you are putting a fuse in your positive line between your battery and starter correct? If so then yes the rest of the system should be just fine as everything else is fed off the fuse box which as I stated is after the alternator.
  1. 1st post lol
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2010, 10:56 AM
  2. Birthday Post
    By GTPluv in forum Off Topic Discussion
    Last Post: 01-04-2008, 04:30 PM
  3. First post! HUD.
    By gmboy in forum Visual/Body Modifications
    Last Post: 12-13-2007, 08:44 PM
