Thread: Help with Install
Results 1 to 5 of 5
  1. #1 Help with Install
    Puyallup, WA
    Hey Guys,
    I am wondering how hard it will/would be to install some 6.5" speakers in the front doors. I have a brand new pair of Diamond Audio Hex components and I want to put them in. Where would u suggest putting the tweeters?
    I also have a Eclipse amp that I will be running them off of. Can I do this and then just leave the stock bose rears and amp for now?
    Your input would be appreciated.
    Thanks,
    02 Silver GTP w/Bose and Onstar
  2. #2 Re: Help with Install
    you would have to custom fit everything for the 6.5 speakers.
    the hole is only 5.25in or whatever the stock size is.
  3. #3 Re: Help with Install
    Houston
    You can easily fit the 6.5's you just have to make your own mount, or modify the stock one.
  4. #4 Re: Help with Install
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Here is my 6.5's mounted in my front door.
    I had to take the door panel of and cut a fairly considerable amount from the panel and fold the leatherette over and glue it, then i baked and fit the standard grills over the curvy area and screwed it in place.
    And tweeters were mounted in the factory location, just cut out the hole and epoxied them in.
    Infinity all around.
  5. #5 Re: Help with Install
    Mar 2012
    Minnesota
    Yep that's why i'm sticking with the stock size. I would hate to cut the door up for them
  1. 04+ HUD Install
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-06-2012, 02:25 PM
  2. cam install
    By 2001goldGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2011, 02:18 PM
  3. What do I need to install a cam?
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 07-28-2011, 12:05 AM
  4. Z7 Install help
    By ARFF22 in forum Turbo
    Last Post: 02-01-2011, 01:35 AM
  5. How Do I install this?????
    Last Post: 11-13-2009, 01:17 AM
