Thread: Will these work for rear deck..?
Results 1 to 7 of 7
  1. #1 Will these work for rear deck..?
    Sep 2011
    Hermitage, PA
    My car is an 05 gp gt with monsoon. I was just wondering will these work well for the rear deck of my car.... Essentially drop right in? I was looking for the momo 6x9 two ways but couldn't find them... Discontinued. If not... any recommendations for a little more bass and loudness. Thanks!
    Polk Audio MM691 6"x9" 3-way car speakers at Crutchfield.com
  2. #2 Re: Will these work for rear deck..?
    GTX Level Member cerick08GP's Avatar
    Well I’m no audiophile, when I replaced my rear deck speakers ANYTHING would have been an upgrade.
    Just incase this is your first time; you do realize the entire back seat needs to be removed to get at those right?
    And yes, any 6x9s should basically drop right in. FYI I had to dremel the $hit out of my mounts to get the cone/magnets to clear.
    If you run into issues I can try to help.
    Good luck
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
    Ohio
    When i swapped my 05s out the whole seat comes out then i think i had to modify the bracket to make them work... And honestly i didnt notice a huge difference in sound... Now in my 97 the speakers need swapped because they suck.... But if i would buy another 05 i would prolly leave the stock system how it was.... I got more bass from the stocks then what i put in but it worked well when i put a sub in
    Sent from my Galaxy Nexus using Tapatalk
  4. #4 Re: Will these work for rear deck..?
    Sep 2011
    Hermitage, PA
    I'm a mechanic... so back seat is no problem. I know the speaker is wires with two sets of wires... one for lows, and one for the mid drivers. But seeing as this is a three way speaker I am not sure how it will sound in the back, or if the addition of the tweeter will be a problem. Also if it will work well with the monsoon system... I know on a base model it would be a good upgrade... just wasn't sure on the monsoon.... should I be looking for a 2 way... or will this work good? Sorry... lol
  5. #5 Re: Will these work for rear deck..?
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    Im running 5 way Kenwood 6x9s in my 2000 off stock wiring and theyve been holding up so i think your 3 way should sound fine for you.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  6. #6 Re: Will these work for rear deck..?
    I really can’t help you with all the tech stuff. I’d just try to hold out for a more knowledgeable person to chime in and/or call Crutchfield.
    2008GP
    2002GP||sold
  7. #7 Re: Will these work for rear deck..?
    Houston
    You really cant go with a three way, the monsoon only puts out low rang and high range. If you really need to replace them, go with a two way 6x9. You'll have to cut the tinsel lead to the tweets and wire them to your high range (I believe dark brown and yellow on the left, and dark blue and light blue on the right) But they wont sound as good as the stock, unless you can power match them.
  1. WTB Bose Rear Deck
    By jwjones in forum Wanted To Buy - Parts
    Last Post: 02-11-2012, 10:40 PM
  2. Rear Deck Spoiler
    By tdm571 in forum Visual/Body Modifications
    Last Post: 01-06-2011, 10:05 AM
  3. best speakers for rear deck 07 gp gt
    By gmoney25 in forum Audio, Security & Visual Electronics
    Last Post: 08-12-2010, 01:55 PM
  4. my alarm dosnt work after i installed a new deck
    By jcs in forum Introductions/Noob Questions
    Last Post: 04-03-2010, 02:34 PM
  5. ported rear deck
    By abuckley1290 in forum Audio, Security & Visual Electronics
    Last Post: 12-09-2009, 03:05 AM
