Thread: Custom Sub Box Location
Results 1 to 10 of 10
HOPPY Custom Sub Box Location 08-20-2008, 09:28 AM
gtpinsc Re: Custom Sub Box Location 08-20-2008, 10:48 AM
BADAZGTP Re: Custom Sub Box Location 08-20-2008, 05:50 PM
HOPPY Re: Custom Sub Box Location 08-20-2008, 07:46 PM
BADAZGTP Re: Custom Sub Box Location 08-20-2008, 07:59 PM
HOPPY Re: Custom Sub Box Location 08-20-2008, 10:20 PM
BADAZGTP Re: Custom Sub Box Location 08-21-2008, 07:54 AM
gtpinsc Re: Custom Sub Box Location 08-21-2008, 02:29 PM
JCG\'s-GTP Re: Custom Sub Box Location 08-21-2008, 07:37 PM
HOPPY Re: Custom Sub Box Location 08-22-2008, 12:09 PM
  1. #1 Re: Custom Sub Box Location
    Apr 2008
    Chillin at the Beach , VA
    Agree^^^^ That's where I put mine also. I think it's because th trunk is so big that you lose your sound before it hits the back of the trunk and bounces back forward. Even if you mount it on the right side at the rear of the trunk, speaker facing back, I think you'll still have ample amount of trunk area to fit your needs. Put, it where you are talking about and see how it sounds, then move it to the rear. Mount in the location that sounds better to you. JMO.
  2. #2 Re: Custom Sub Box Location
    SE Level Member HOPPY's Avatar
    Jul 2008
    Howell, MI
    Alright cool sounds like this spot wont be to bad then, maybe i'll even angle the sub alittle towards the trunk opening. Also would it matter if the box is not a cube/rectangle?
  1. Name this Part and location?
    Last Post: 06-24-2008, 08:37 AM
  2. Paint code location?????
    By duane9586 in forum Visual/Body Modifications
    Last Post: 06-22-2008, 09:32 PM
  3. pcm location
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 04-08-2008, 03:46 PM
  4. Location of PVC Valve
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 08:49 AM
  5. User location Map
    By 3800SE in forum Forum Bugs/Suggestions
    Last Post: 01-25-2008, 08:23 AM
