Thread: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
Results 1 to 20 of 26
  1. #1 Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Aug 2008
    Phoenix Az
    I have a 06, and I just installed a 760 Watt Pioneer Amp W/2 12' Pioneer Speakers to my stock deck. The New Deck is coming down the road, well I am still stuck between the fact after of spending 2 days on getting through the fire wall for the power wire. Now the brick wall that I have infront of me is how do I run my remote power wire to my Key/Ignition Power Wire.. Well with all the searching, haven't found a diagram or even anyone else who would know where the Key/Ignition power wire is?? Hopefully you guys can help. At this moment I am running my remote wire, I'll know you laugh but to the Truck Light Remote wire in my trunk.. So basically like normal Grand Prix's its basically hook up to my lights and my amp turns off during the day unless I have the lights on.. Does anyone know where to locate the Key/Ignition Power wire so I can run my remote wire for my amp? Thanks In Advance
  2. #2 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    Run it straight to the fuse box off a fuse that comes on only when the cars on I.E. power antena , windows, sun roof ect...
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  3. #3 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Aug 2008
    Whitby Ontario
    Quote Originally Posted by AhtomusPrime View Post
    LOL thats funny S*&^. do you have an aftermarket deck? why didn't you run a single wire from the back of the deck, to the remote port beside the power in the amp???
  4. #4 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Feb 2008
    Nashville
    Read the thread close... Factory deck. That is why its not just as easy as running a wire from the remote wire on the back of the deck.
  5. #5 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Apr 2008
    Chillin at the Beach , VA
    HAHA!!! Some people think they know it all.lol!!!
  6. #6 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Jersey
    lolz
    16' wrx sti- stock
  7. #7 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Aug 2008
    Whitby Ontario
    lol my bad, was reading on mobile phone, not paying attention..
  8. #8 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Apr 2008
    It's all good man, just picking with you.
  9. #9 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Aug 2008
    Phoenix Az
    Does anyone besides JCG-GTP know any other ways?
  10. #10 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Jersey
    Thats pretty much the standard way of running your remote wire. I used to install the remote wire the same way when i used to work in the install bay at BEST BUY. If, you tap into a fuse in the fuse box make sure u check and see witch prong on the fuse has the postitive current flowing through it. U could also tap directly to your ignition wires. Go to Directechs.com that should tell you everything you would need to know to find a wire to tap into if that doesent work im sure there is a wiring diagram somewhere on this forum or another GP forum
    16' wrx sti- stock
  11. #11 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Apr 2008
    The only other way is to run it to a toggle switch, but then you have to turn it on and off every time you listen to the radio. If you forget to turn it of, you'll end up with a dead batt. Wouldn't recommend this way unless really nessesary. If you want to take the time, you can find and tap into the radio power wire that gives the radio power when the ignition is on. It's just easier running to the fuse box though.
  12. #12 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Jersey
    We used to just run it to the fuse box, less work, i always tried avoiding getting to the back of the radio like an Acura TL Son of a Bit** took 3 hours to get the back of the factory unit! Are cars are so easy though
    16' wrx sti- stock
  13. #13 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Apr 2008
    Yea, I'd run to the fuse box before anything else first to, but you know some like to go the hard route. That's why I put that out there. The fuse box also has the acc. spare connector to were you can wire in that way also. Just gotta buy some of the clips to tie in.
  14. #14 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    SE Level Member armcclure's Avatar
    Fort Wayne, Indiana
    Quote Originally Posted by JCG's-GTP View Post
    This is what i did, and it works great, but if you do it this way add a toggle switch in the line also. This way anytime you turn the radio off for some reason, you can also turn off the amp. If i have the radio off and forget to turn the amp off too, there is a humming noise that comes through the subs. Adding the switch eliminates that.
  15. #15 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Jersey
    Quote Originally Posted by armcclure View Post
    or just tap the remote into the radio fuse, it will eliminate the need for a switch.
    16' wrx sti- stock
  16. #16 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Fort Wayne, Indiana
    Quote Originally Posted by 99prixgt View Post
    NO, it does not. The Radio power (turn on) fuse is just a branch of the ignition switch. In an aftermarket head unit, turning it off turns off power to the amp. When you turn your radio off, the radio power fuse is still active.
  17. #17 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Feb 2008
    Nashville
    Um.. what? You confused the hell out of me lol. Mine was ran there before I put the Kenwood in and I never had a problem.
  18. #18 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Apr 2008
    He's just saying that running the remote wire to the box with a fuse that gets power when the ignition is on, the amp will continue to be on when he cuts the radio off. Obviously. But, he says when he does this, he gets noise through the subs which happens with some amps that have power to them with no sound. so he basically ran a toggle switch to cut the amp off when he cuts the radio off.
  19. #19 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Jul 2008
    sumter,south carolina
    sounds like some ghetto rigged stuff to me
    02 GTP with mods 05 GP for DD
  20. #20 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Feb 2008
    Nashville
    Thats why you dont turn your radio off. Problem solved
  1. Where to run power wire?
    By 97gp97 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 02:21 PM
  2. Wiring Remote Wire help!
    By adrenaline54 in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2008, 10:49 AM
  3. How to hook up the A/D inputs on the DHP Powertuner?
    By Iron Indian in forum PCM Tuning
    Last Post: 06-25-2008, 09:01 AM
  4. OBD 2 wire
    By bula81069 in forum PCM Tuning
    Last Post: 04-14-2008, 11:25 AM
