Thread: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
Results 1 to 20 of 26
Threaded View
AhtomusPrime Where Do I Find My... 08-19-2008, 09:47 PM
JCG\'s-GTP Re: Where Do I Find My... 08-19-2008, 10:30 PM
armcclure Re: Where Do I Find My... 09-11-2008, 10:06 PM
99prixgt Re: Where Do I Find My... 09-12-2008, 06:11 PM
armcclure Re: Where Do I Find My... 09-12-2008, 08:45 PM
JCG\'s-GTP Re: Where Do I Find My... 09-14-2008, 07:02 PM
cobraz Re: Where Do I Find My... 08-27-2008, 07:32 AM
JCG\'s-GTP Re: Where Do I Find My... 08-27-2008, 04:37 PM
BADAZGTP Re: Where Do I Find My... 08-27-2008, 09:40 PM
99prixgt Re: Where Do I Find My... 08-27-2008, 10:43 PM
cobraz Re: Where Do I Find My... 08-28-2008, 07:09 PM
BADAZGTP Re: Where Do I Find My... 08-28-2008, 08:11 PM
AhtomusPrime Re: Where Do I Find My... 08-29-2008, 12:13 AM
99prixgt Re: Where Do I Find My... 08-29-2008, 01:15 AM
BADAZGTP Re: Where Do I Find My... 08-29-2008, 10:07 AM
99prixgt Re: Where Do I Find My... 08-29-2008, 05:14 PM
BADAZGTP Re: Where Do I Find My... 08-29-2008, 05:51 PM
BADAZGTP Re: Where Do I Find My... 09-14-2008, 07:28 PM
JCG\'s-GTP Re: Where Do I Find My... 09-14-2008, 07:37 PM
BADAZGTP Re: Where Do I Find My... 09-14-2008, 07:38 PM
gtpinsc Re: Where Do I Find My... 09-14-2008, 07:34 PM
armcclure Re: Where Do I Find My... 09-15-2008, 11:11 AM
BADAZGTP Re: Where Do I Find My... 09-14-2008, 07:37 PM
archemedes Re: Where Do I Find My... 09-15-2008, 12:08 PM
reinke Re: Where Do I Find My... 11-04-2008, 12:57 PM
armcclure Re: Where Do I Find My... 11-04-2008, 12:05 PM
  1. #14 Re: Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    Jersey
    Thats pretty much the standard way of running your remote wire. I used to install the remote wire the same way when i used to work in the install bay at BEST BUY. If, you tap into a fuse in the fuse box make sure u check and see witch prong on the fuse has the postitive current flowing through it. U could also tap directly to your ignition wires. Go to Directechs.com that should tell you everything you would need to know to find a wire to tap into if that doesent work im sure there is a wiring diagram somewhere on this forum or another GP forum
    16' wrx sti- stock
  1. Where to run power wire?
    By 97gp97 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 02:21 PM
  2. Wiring Remote Wire help!
    By adrenaline54 in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2008, 10:49 AM
  3. How to hook up the A/D inputs on the DHP Powertuner?
    By Iron Indian in forum PCM Tuning
    Last Post: 06-25-2008, 09:01 AM
  4. OBD 2 wire
    By bula81069 in forum PCM Tuning
    Last Post: 04-14-2008, 11:25 AM
