BillBoost37
If you head to the parts stores etc..most of the prongs/connectors are meant to work together. I've never looked at the sizing other than the gauge of the wire for the connector.
What you need to do is run a ground wire to pins 30 and 85 from the body or the radio ground. Run the amp turn on wire from your head unit (blue/white) to pin 86 and then run your parking brake wire from the radio to pin 87. If your relay also has an 87A, do not connect anything to it.
What this will do is make the radio connect it's own ground to the parking brake wire when it turns on the remote amp. I've tested this in a Pioneer a couple of times and it works great.
