I doubt it, but a proper ground is extremely important so it is possible. The length is not the real issue, its the founding point itself, you have to make sure you have a solid connection between the metal of the car and the grounding wire. If your pretty sure your ground is good, I would test and see if its your head unit by unplugging your RCA's and use and iPod to play some tunes.
