Thread: Hippo's Audio Build Help
Page 18 of 22 FirstFirst ... 81617181920 ... LastLast
Results 341 to 360 of 422
  1. #341
    SE Level Member GiAnT4LYFE's Avatar
    Apr 2009
    Delaware
    Birch is lighter and you don't get MDF bugers. I will be using birch when I build my 4th order.
    Side note, it's your car so you can just ignore my comment.....but I fail to see why you want the tweeters near your sub. You won't hear them at all inside your car. Unless your tailgating, which then I would put a component set in the trunk...still not on the box, it'll end up being a waste. Move those same tweeters to your A or B pillars and you'll be happier. But it's your build and car so do what floats your boat.
  2. #342 Re: Hippo's Audio Build Help
    Houston
    Quote Originally Posted by GiAnT4LYFE View Post
    They're bullet tweeters, so they wont fit in any of his pillars without making some custom pods. We already told him about them in the sub enclosure, but he's set on doing it.
  3. #343 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    Can you guys just drop the tweeters? None of you guys have done it. So let me tell you how it goes ok? God.
    iLoveSpade
  4. #344 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    Which amp
    The Powerbass ASA 1100.5x for $220
    OR
    The MB Quart ONX4.80/500 for $280
    iLoveSpade
  5. #345 Re: Hippo's Audio Build Help
    Houston
    I have never worked with nor heard of powerbass. I have only worked with MB quart 4 channel amps, so I'm unsure of what the bass SQ is. But the 4 channel amps put out some clean sound and I would expect the sub channel to do the same, especially from MB quart. So that's my vote.
  6. #346 Re: Hippo's Audio Build Help
    Sep 2011
    Arkansas
    Powerbass has some excellent amplifiers. In my opinion, it's a draw... although I'm thinking the Powerbass may be SLIGHTLY better-built, seeing as how MBQ makes the Onyx line significantly less beefy than the Discus line was... However, I'm sure either amplifier will suit your needs.
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  7. #347 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    Never heard of powerbass? lol
    I have a question, do I have to worry about like stereo or mono when hooking up my amp to the speakers? Can someone explain that to me
    iLoveSpade
  8. #348 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    Also, I liked the MB Quart because of the option of having 1 ohm impedance, but if you think powerbass will be better I'll get it .
    iLoveSpade
  9. #349 Re: Hippo's Audio Build Help
    Sep 2011
    Arkansas
    I think it'll be a draw, in all honesty... pick whichever one fits your subwoofer's needs, and the rest will be all good.
  10. #350 Re: Hippo's Audio Build Help
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Quote Originally Posted by Hippo Machine View Post
    Your front and rear channels will be in stereo, hence there is a right and left speaker while your rear will be mono because it is unidirectional and there is only one speaker.
    Infinity all around.
  11. #351 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    ^ k
    Installed the dynamat in the doors today, and like what I hear
    iLoveSpade
  12. #352 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    I also plugged the stock tweeters back in. Sounds slightly slightly better with them.
    iLoveSpade
  13. #353 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    I800 what do you think. MB Quart or Powerbass. I need reassurance. I really don't know if 250w rms will be enough for that sub (prolly will though)
    iLoveSpade
  14. #354 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    UH lulz just REALLY took into account how huge that MB QUART one is. the Powerbass is 4 inches shorter.
    iLoveSpade
  15. #355 Re: Hippo's Audio Build Help
    Feb 2009
    Virginia
    Shoulda bought my leviathan
    11 is louder than 10!
  16. #356 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    I kinda have an idea. What if I bought two 8" subs that I could wire everything together to 2 ohms and make a 3 sub enclosure?
    iLoveSpade
  17. #357 Re: Hippo's Audio Build Help
    Nov 2008
    Waterloo, Iowa
    Mixing sizes is generally bad.
  18. #358 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    Is there reasoning to that jw
    iLoveSpade
  19. #359 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    cuz if i wired it at 3 ohms i would get like 320w rms to each of the 3 subwoofers right? I would just get 2 of the Lanzar 300w rms 8"
    iLoveSpade
  20. #360 Re: Hippo's Audio Build Help
    Feb 2009
    Virginia
    There's nothing wrong with it but it's generally not done because it's kind of impossible to predict the characteristics and behavior. You'd certainly know after the fact when you get measuring equipment but I think it's also heavily influenced by the show quality of a mix/match install vs. a single theme or brand.
    But, each speaker(assuming they're equal) adds ~3db output so there's definitely an upside too
  1. Hippo, take notes
    By EJOUIE in forum Off Topic Discussion
    Last Post: 11-11-2011, 09:13 PM
  2. Blackbonnie's 05 GP GT audio build log
    By blackbonnie in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2009, 12:40 AM
  3. well I am starting a new audio build. This time it is sq.
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2008, 06:08 PM
