Thread: Hippo's Audio Build Help
Results 1 to 20 of 422
  1. #1 Re: Hippo's Audio Build Help
    Topeka, KS
    I've seen peeps use 0ga wire for the big 3 and they actually picked up a mpg.
  2. #2 Re: Hippo's Audio Build Help
    Nov 2008
    Waterloo, Iowa
    Quote Originally Posted by rynoman03 View Post
    Wouldn't doubt it. Modern day cars depend so much on the electrical running smoothly, if you have better, less resistant flow... anything is possible.
  3. #3 Re: Hippo's Audio Build Help
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Funny you should say that. Larger wire is more resistant than smaller. The only reason you use larger gauge wire for such projects is to make sure of can handle the increAsed amperage without getting too toasty. Anyhow, unless you planning on putting more than 1K watts worth of stereo in your car, I wouldn't worry too much about this big three upgrade. Just a huge expenditure of money for no gain. The only reason you should do that upgrade is because you have too. The stock alternator and wiring should do okay with draws less than 1k, above that however, the big three is critical.
    Infinity all around.
  1. Hippo, take notes
    By EJOUIE in forum Off Topic Discussion
    Last Post: 11-11-2011, 09:13 PM
  2. Blackbonnie's 05 GP GT audio build log
    By blackbonnie in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2009, 12:40 AM
  3. well I am starting a new audio build. This time it is sq.
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2008, 06:08 PM
