Thread: Hippo's Audio Build Help
Results 1 to 20 of 422
  1. #1 Re: Hippo's Audio Build Help
    Nov 2008
    Waterloo, Iowa
    Drill holes exactly the size you need in the box, run wire through, after they're connected to the subs pull them through until they're about as tensed as possible, then slack up on them a little. After that maybe a bit of silicon around the edges of the holes for added security.
  2. #2 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    Also should I wire it at 1 ohm if the amp I get can handle it?
    iLoveSpade
  1. Hippo, take notes
    By EJOUIE in forum Off Topic Discussion
    Last Post: 11-11-2011, 09:13 PM
  2. Blackbonnie's 05 GP GT audio build log
    By blackbonnie in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2009, 12:40 AM
  3. well I am starting a new audio build. This time it is sq.
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2008, 06:08 PM
