Having done quite a few installs, I would, without a doubt lOok at getting one amplifier to replace all three. There is no reason, unless you need the increased power output to have multiple amplifiers where one would surfice. I would look into a 5 channel amplifier to drive your entire system. It's so much easier installation wise, and cheaper. Save yourself the time and money and get a good 5 channel amp, or, if you must, two amplifiers but three just seems silly.
There's a few reasons you run multi channel amps and I don't think they apply here.
1) Channel separation. It doesn't matter who made what, there's cross talk inside an amplifier. Best way to get rid of that is a separate power supply/separate amp.
2) Redundancy so that in case of failure you aren't replacing one extremely expensive amp; only "part" of the system
3) Power requirements. I don't really want to explain...so here's one word; transient.
I highly doubt your install takes any of these into account. I'd say 2 amps can be efficient and 3 amps starts some head scratching
How bout this 5-channel? Boston Acoustics GTA-1105 5-channel car amplifier — 70 watts RMS x 4 at 4 ohms + 400 watts RMS at 2 ohms at Crutchfield.com good power for the four speakers, and 250w rms for the sub (sub rated at 300w rms).
anyone??
I was pretty impressed with those boston amps. I never had one come back blown after an install. It doesnt say at what ohm the sub needs to run at for 250w rms. I'll look into it.
I like this one...pretty close except the GT-50 is made in Italy and uh...nothing else matters
Server error
Boston Acoustics GT-50 5-channel car amplifier — 55 watts RMS x 4 + 250W x 1 at Crutchfield.com
doh!...it's sold out :/
What sub are you running, again?
Rockford Fosgate P3D2-12 DVC gonna wire it at 4 ohms.
that amp is 250w x 1 @ 4 ohms, so it would work for errrythingg
its 600w RMS at 2 ohms, not 4 ohms I thought..
Disregard that^^ lol don't even know what I'm saying. I thought it was 300w rms.
Doesn't look like I'll find a 5-channel for a reasonable price with enough power for my sub then. Looks like I'll have to go to 2-amp set up, just a mono for now.
Well that's the thing, it doesnt say if its 600W rms at 1ohm or at 4ohm.
EDIT: Scratch that, I forgot we are talking about subs, not amps. Its gonna require 600w rms no matter what impedance you run it at. I would get the amp you want, then match the sub to that amp.
doesnt hurt to have some room, but more power=more money (generally) so it's up to you
I think I will do it, because it will save me a lot of money and pain when wiring. Also 250w RMS is probably plenty of power for me.
