Thread: ported 10 sub box
Results 1 to 14 of 14
  1. #1 ported 10 sub box
    Lawton, ok
    I have 2 jl audio 10w1v2 i want to put in a custom build ported box.. wanting to know if anybody has had these in a ported box or a sealed box what is the best sounding one of the two.. i have an 06 grand prix gt
  2. #2 Re: ported 10 sub box
    GT Level Member Peacher213's Avatar
    STL Metro Area
    Its all up to you. I prefer sealed boxes myself. Much more of a flat bass responce. Ported is definantly louder. However, you will have a much louder spl at certain frequencies, while others will fall out. I listen to all types of music. So, a sealed box is a must for me.
  3. #3 Re: ported 10 sub box
    Lawton, ok
    i listen to alot of music as well.. what would be a good size box for these i know what jl recommends but what do people with incar experience have to say
  4. #4 Re: ported 10 sub box
    STL Metro Area
    Id build the largest box they recommend. If you get too big it sounds like poo.
  5. #5 Re: ported 10 sub box
    STL Metro Area
    Ive never owned JL, however, my friend had w 12" w0 subs hooked up in an old school PRO ROCKS BOX with a little over 1cuft per sub. Sounded really good when powered by a rockford 300.2
  6. #6 Re: ported 10 sub box
    GTP Level Member
    Nov 2011
    Kansas
    I like sealed boxes as well. Ported is louder, but from my understanding, you dont have as much control over the woofer. Sealed takes more power to get the same results as a ported but is often a cleaner sound.
  7. #7 Re: ported 10 sub box
    STL Metro Area
    Exactly /\
  8. #8 Re: ported 10 sub box
    Lawton, ok
    Wall Thickness 0.75 in / 19 mm
    Front Baffle Thickness 0.75 in / 19 mm
    Volume (net int.) 0.625 cu ft / 17.7 L
    External Width (W) 16.5 in / 419 mm
    External Height (H) 13.5 in / 343 mm
    External Depth (D) 7.75 in / 197 mm
    F3 44.7 Hz
    Fc 49.5 Hz
    Qtc 0.795
    that for a single they don't have a dual box spec
  9. #9 Re: ported 10 sub box
    STL Metro Area
    3/4" Mdf will be plenty thick for the box. You should be fine with up to a 1.5 cu ft box for 2 10s. The bigger the box the more BOOMY the sound. More lows but less mid-higer bass frequencies. If you choose, you can place a divider in the middle of the box so each woofer has its own enclosure.
  10. #10 Re: ported 10 sub box
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    3/4 Birch wood IMO
    sealed is much more peaky than a proper flat response ported box.
    but what do i know i've heard em both in alot of different cars on alot of music
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  11. #11 Re: ported 10 sub box
    STL Metro Area
    Enclosure Compatibility
    Recommended Sealed Box Volume: The sealed box size recommended by JL Audio is 0.625 cu/ft. A diagram is provided in the owner's manual for a sealed box with external dimensions of 16.5" W x 13.5" H x 7.75" D, assuming 3/4" thick material. (If you are using 5/8" thick materials, you should subtract 1/4" from each dimension.)
    Recommended Ported Box Volume:The ported box size recommended by JL Audio is 1.00 cu/ft. A diagram is provided in the owner's manual for a sealed box with external dimensions of 18" W x 13.25" H x 13.5" D, assuming 3/4" thick material. (If you are using 5/8" thick materials, you should subtract 1/4" from each dimension.) A slot port is recommended with the following dimensions:
    • Slot Width =1.0"
    • Slot Height = 11.75"
    • Slot Length = 29.0" (a right angled port with a 13.75" extension)
    http://www.crutchfield.com/S-DXK3VU0...ml#details-tab
  12. #12 Re: ported 10 sub box
    Feb 2009
    Virginia
    Quote Originally Posted by 1LoudGrandPrix View Post
    3/4 Birch wood IMO
    If it was just a sealed box and it's response being tested...then it's closer to flat without hassle vs. ported. But we're putting a box inside a box(car). The second box, our car, is creating those peaks. That's why car audio = trail and error. Every car(box) is a different shape :/
    11 is louder than 10!
  13. #13 Re: ported 10 sub box
    Cedar Rapids, IA
    i can already tell you the cabin gain is in the 45-47 i don't know about the trunk and cabin gain its never been relevant to my builds
  14. #14 Re: ported 10 sub box
    GTP Level Member
    springfield IL
    Aim for a box qtc of .7 Sealed
