Thread: Oem nav install in base model
Results 1 to 7 of 7
carriaga89 Oem nav install in base model 02-23-2012, 04:54 PM
simbah Re: Oem nav install in base... 02-23-2012, 07:48 PM
carriaga89 Re: Oem nav install in base... 03-02-2012, 01:04 PM
OH4CompG Re: Oem nav install in base... 03-02-2012, 01:47 PM
carriaga89 Re: Oem nav install in base... 03-02-2012, 01:50 PM
DCGTP Re: Oem nav install in base... 05-31-2012, 12:46 PM
rodman Re: Oem nav install in base... 09-15-2017, 03:42 PM
  1. #1 Oem nav install in base model
    SE Level Member carriaga89's Avatar
    Texas
    On my previous thread I had stated I am getting a new OEM NAV for my 2006 GP Base /w onstar and 1-disc stereo... I'm pretty tech savy and good at following guides/directions etc. so I will need to know how to install this NAV unit on my model.
    These are the items I believe I need please correct me if i'm wrong
    1. OEM GPS NAV UNIT
    2. VSS HARNESS
    3. Amp of some sort as I do not have the monsoon system
    4.GPS NAV antenna
    I also saw that if I have speed compensated volume then I may already have the VSS installed?
    I have seen a few guides but the pictures are no longer hosted etc and they are very basic guides and don't tell me to much on how to install it.
    If anyone could help me out.. post some guides pictures ... links to a guide what have you I would really appreciate it... I could just take it to a shop but I don't want to pay $500 plus to get it installed! lol Thanks again!
  2. #2 Re: Oem nav install in base model
    GTP Level Member simbah's Avatar
    Lala land
    You are missing one very important step, radio will not work without this important step. You have to take car with new radio installed to dealer and have car and radio programmed to work with each other. About $100, no way around this step.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: Oem nav install in base model
    Texas
    Ok so I have installed the unit myself minus the VSS and GPS antenna as I dont really care for the GPS part... So dealer unlocked it for $85 ... total spent $250 to get this thing.... but now I have another issue the system is very quite when it is maxed the volume is low my guess is i need a amp any one agree ?
  4. #4 Re: Oem nav install in base model
    Portland Oregon
    I'm betting it's set up for the amplified system.
  5. #5 Re: Oem nav install in base model
    Texas
    Yea me to ... I saw a thread were someone used an old amp but cant seem to find it anymore
  6. #6 Re: Oem nav install in base model
    SE Level Member DCGTP's Avatar
    Charleston SC
    the factory nav was only available on the monsoon equipped vehicles which used external amplifiers. so yes, you will need to amplify your unit.
    I've got the factory nab and monsoon system the antenna and on star all in my car but i don't think my nav is connected to the VSS. can you post the link to the guide you're using? I'm interested in using the nav since mine came with a map disk
    Overkilled, AL605s, 180 T-stat, Cone Intake, Cross drilled & Slotted Rotors, f-body upgrade, poly upper mounts, shorter dog bones,
    factory nav, 2x12s in the trunk, interior LED swap, all 5000k HIDs, red halo's in upper grille, tinted tails and reverse lights, de-badged, XM to line in conversion
  7. #7 Re: Oem nav install in base model
    GT Level Member rodman's Avatar
    Apr 2008
    I have the same issue.....low volume so if I buy the monsoon amp is the wiring harness there ???
  1. Base model vs GT
    By midrange in forum General Grand Prix Discussion
    Last Post: 02-16-2012, 01:35 PM
  2. My Girl's '06 Base Model
    By Swiggles in forum Members Rides
    Last Post: 12-02-2011, 04:38 PM
  3. Diffrence from a base model and a gt?
    By 2004GOATLS1 in forum General Tech Discussion
    Last Post: 11-14-2011, 01:15 PM
  4. adding fog lights to a base model GP
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 11-07-2011, 07:36 PM
  5. Base model in need of a Supercharger
    By imjustanobody34 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2009, 12:07 PM
