Thread: pac swi x install help
Results 1 to 9 of 9
  1. #1 pac swi x install help
    GT Level Member des19's Avatar
    May 2011
    Ontario
    Hi has anyone installed one of these? It says to install the power and ground wires to any source. Okay easy enough. But then it says to install the green wire to the vehicle SWC wire? Does anyone know what this means? Can it be connected to any green wire source or does it need to be connected to a certain one??
    the manual is here if this can help any one.. http://www.pfyc.com/supportfiles/swixinstr.pdf
  2. #2 Re: pac swi x install help
  3. #3 Re: pac swi x install help
    May 2011
    Ontario
    thanks
  4. #4 Re: pac swi x install help
    May 2011
    Ontario
    sorry about to do this install tomorrow...does the green wire at that connects to pin A7 have to be at the swc or can it be at the radio also???
  5. #5 Re: pac swi x install help
    May 2011
    Ontario
    anyone???
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    I installed that on my old 99 prix and the wire was in the radio harness.
  7. #7 Re: pac swi x install help
    May 2011
    Ontario
    Quote Originally Posted by Compg4me View Post
    Do I need to cut the pin at A6 and connect it to a 12v or can I cannect a 12v directly to the harness without cutting? (for pac swi x)
  8. #8 Re: pac swi x install help
    Dec 2008
    Lawndale, CA
    Find the wire on the harness. Cut it and splice it into the PAC wire. Tape it up and you are done.
  9. #9 Re: pac swi x install help
    Oct 2011
    Toledo, OH
    Thanks! This just made my day easier. Searching GPF is better than Google sometimes.
    The GMOS-04 doesn't come with that wire, but I pulled the Illumination wire out of B12 and snapped it into A7 since I'll be using the Dimmer wire.
    7"
  1. Cam Install
    By lflylow in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2011, 10:54 AM
  2. Gen V Install
    By BoostnBlackGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2010, 09:04 PM
  3. How Do I install this?????
    Last Post: 11-13-2009, 01:17 AM
  4. HUD Install
    By Rather B Blown in forum General Tech Discussion
    Last Post: 11-12-2009, 11:12 AM
  5. Do I need a cam kit to install a VS cam
    By ncccgolf5 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2009, 02:51 AM
