Thread: HID Install help?
Results 1 to 16 of 16
  1. #1 Re: HID Install help?
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    ok first off you dont need capasitors thats what the relay harness will fix! what happens with a lot of these kits is that you can plug some of the connectors in 2 ways. there is a top and a bottom to the connector but when you plug in the 2 prong plug into the ballast switch it around! turn it upside down and try it like that. i have had this problem twice. its weird. let me know if you dont understand. but take the plug that goes from the bulb to the ballast and rotate it 180 degrees and try it again! these plugs will go in both ways. i bet this is your problem.
  2. #2 Re: HID Install help?
    Dec 2010
    ATL,Georgia
    Quote Originally Posted by RyanL View Post
    ok first off you dont need capasitors thats what the relay harness will fix!...
    you will most def need the capacitors/anti-flicker to take care of the DRL problem.. i couldnt get mine to stop flickering with out them.. even with a wire harness
  1. 04+ HUD Install
    By Explicit_Spade in forum 04+ Specifics
    Last Post: 03-02-2016, 11:03 PM
  2. Aux In Install GP +04
    By JohnnyTwoTimesTwoTimes in forum Audio, Security & Visual Electronics
    Last Post: 08-19-2014, 10:10 PM
  3. vs cam install
    By Silver GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2010, 04:09 PM
  4. big install
    By BoostJunki3 in forum Audio, Security & Visual Electronics
    Last Post: 12-30-2009, 12:25 AM
  5. Hv3 install help
    By PWNED in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-24-2009, 04:00 PM
