Where can I find a 12v source on my cart that only powers up after the vehicle is started? Again, I don't want it to power up when the key is turned forward but only when the vehicle turns over. And ideas?
Try this on a fuse that only works after ignition.
(1) ATM Mini Fuse Tap Add on Dual Circuit Adapter Auto Car Audio Terminals | eBay
That might work but is there a spot to hook up without adding anything
I'm pretty sure there is a empty 12v source in the fuse block under the hood that only works when the car is on.
What are looking to power only after you started the car? The only way I can think is to just add a switch to a constant or switched 12v source, and turn it on after you've started the car.
