Thread: Run wires from amp to battery
Results 1 to 14 of 14
  1. #1 Run wires from amp to battery
    SE Level Member Mayer76's Avatar
    Shoemakersville, Pennsylvania, United States
    I need help to know where to run my power to my battery. I have a 2000 Pontiac Grand Prix GTP.
  2. #2 Re: Run wires from amp to battery
    put it on the top post on of the fuse block(under the red cap if your still has it)
    SMGPFC Member #10
  3. #3 Re: Run wires from amp to battery
    Okay. I run the wire though the firewall right?
  4. #4 Re: Run wires from amp to battery
    yes theres a gromet there in the firewall
    SMGPFC Member #10
  5. #5 Re: Run wires from amp to battery
    I tryed looking for that today. Is that on the passenger side and when u lift up the carpet a little bit its that little hole there? Is that right?
  6. #6 Re: Run wires from amp to battery
    yea its a pain to find from the inside, like right behind heater box but towords the passenger side, i had to stick a coat hanger though the engine bay side to find it
    SMGPFC Member #10
  7. #7 Re: Run wires from amp to battery
    heres a pic of the floor bored, doesnt really show it but follow the wires and its up where the red and blue wire meets
    SMGPFC Member #10
  8. #8 Re: Run wires from amp to battery
    So its up a little but from that hole?
    Nicholas Mayer
  9. #9 Re: Run wires from amp to battery
    yea its up there quite a bit.
    SMGPFC Member #10
  10. #10 Re: Run wires from amp to battery
    Okay. So i just need to pull the carpet back and thats it? When i get it threw how do i run the wire? Can i hook it up to the fuse box? Or does it have to go on the battery? I know u answered this already but i wanna make sure im ok. I have an aftermarket radio its a Pioneer. There is a blue wire hookup in the back of it thats where i connect the blue wire frok the amp to right?
    Nicholas Mayer
  11. #11 Re: Run wires from amp to battery
    dont think so, you amp power wire should go on the top post to the fuse box, the amp doesnt get power from the HU, just signals
    SMGPFC Member #10
  12. #12 Re: Run wires from amp to battery
    Okay well in my last car i had to hook my amp up to a blue wire in the head unit. Okay so i can use the fuse box sweet. Thx. That saves me from running it to the battery and wasting that wiring. Thank u for your help.
    Nicholas Mayer
  13. #13 Re: Run wires from amp to battery
    no problem anytime
    SMGPFC Member #10
  14. #14 Re: Run wires from amp to battery
    Houston
    As dpzelenak said, hook you main power wire here. (the fuse is circled, very important) But your HU is not just for signal. You will need to connect your amps remote wire to the amp turn on lead of your HU. Usually blue from the HU harness.
  1. Amp to Battery
    By SE2001 in forum Audio, Security & Visual Electronics
    Last Post: 02-11-2012, 02:33 PM
  2. new battery? maybe?
    By tcafego in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2011, 11:48 PM
  3. battery
    By kjohnson in forum General Tech Discussion
    Last Post: 09-08-2010, 11:05 PM
  4. Battery
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2009, 11:21 AM
  5. battery help!
    By DDPeppa in forum General Tech Discussion
    Last Post: 08-23-2009, 11:49 PM
