Thread: need help wiring subs in 99 Grand Prix
Results 1 to 9 of 9
  1. #1 need help wiring subs in 99 Grand Prix
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i have a 99 grand prix and i need to know wheres the best and easist way to run the power wire through the firewall? pictures would be greatly apprecieated because ive been looking and looking and i cant find anywhere to run it that wont interfear with my driving, thank you.
  2. #2 Re: need help wiring subs in 99 Grand Prix
    Apr 2011
    Athens, AL
    There's a big rectangular grommet in the passenger floorboard. If you pull your carpet back some you'll see it. It will pop into the car if you pull on it. Or just drill a hole through the firewall.
  3. #3 Re: need help wiring subs in 99 Grand Prix
    Oct 2011
    Michigan
    yeah thats a drain plug though and isnt it bad to have the wire exposed and so close to the ground??
  4. #4 Re: need help wiring subs in 99 Grand Prix
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    I wouldn't ever worry about it. Almost all of us run our main power wire through that hole. Run the power wire inside some plastic tubing that will protect it inside of the engine bay from heat, debris, and water. Then drill a hole and pull wire through so its tight and no water could ever get through. Then your good to go.
    Infinity all around.
  5. #5 Re: need help wiring subs in 99 Grand Prix
    Oct 2011
    Michigan
    why would i need to drill a hole if im running it through the drain plug?
  6. #6 Re: need help wiring subs in 99 Grand Prix
    Im not sure if its a drain plug... Its a rubber cap that fits in a fairly decent size hole in the firewall on the passenger side of the car, I'm not sure that its low enough to drain water however. Its decent size and I'm not sure you want to keep a hole like that open to the elements. Thats why i suggested just drilling the correct size hole for whatever gauge your running and make sure its tight fitting. No water leaks!
  7. #7 Re: need help wiring subs in 99 Grand Prix
    Oct 2011
    Michigan
    ohhh ok and yes its a drain plug
  8. #8 Re: need help wiring subs in 99 Grand Prix
    Houston
    I think chamilton is talking about the wire harness grommet thats on the passenger side firewall, not the floorboard. Its about even with the power steering pump. Thats where I went through as well.
  9. #9 Re: need help wiring subs in 99 Grand Prix
    Oct 2011
    Michigan
    oh i thought everyone was talking about the drain plug on the floor board
  1. Need Help Installing Subs in 05 Grand Prix
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2012, 03:03 PM
  2. 04 Grand Prix gauge wiring help.
    By WayneG99 in forum Audio, Security & Visual Electronics
    Last Post: 06-28-2011, 03:03 PM
  3. Grand prix 2001 gt 6x9 wiring
    By beerfun in forum Audio, Security & Visual Electronics
    Last Post: 08-12-2010, 11:56 PM
  4. 97 Grand Prix Gt wiring issue
    By GXP Bill in forum Audio, Security & Visual Electronics
    Last Post: 03-14-2010, 09:45 PM
