Thread: quick question aboutan amp
Results 1 to 11 of 11
  1. #1 quick question aboutan amp
    GT Level Member natethegreat's Avatar
    Brookings, SD
    Hey, i was wondering if i can get away with using onelarge amp to run the doors/6x9's/1-210 inch subs? or woukdbe better yo just run two separate amps? Thanks!
  2. #2 Re: quick question aboutan amp
    Yoga city
    u talking a 5 channel bad boy or runnign them all of two channels?
  3. #3 Re: quick question aboutan amp
    Brookings, SD
    Well the fist on a five channel or the doors a rear deck on a 4 channel with the subs on there own amp.
  4. #4 Re: quick question aboutan amp
    Nov 2009
    illinois
  5. #5 Re: quick question aboutan amp
    Sep 2011
    Arkansas
    Do you have any subs in mind? A couple of low-powered 10s would do nicely on that 5-channel 2000GTGP just posted.
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  6. #6 Re: quick question aboutan amp
    Brookings, SD
    was thinking a single 10, maby two
  7. #7 Re: quick question aboutan amp
    Apr 2011
    Athens, AL
    Just check your prices comparing a five as compared to a two and a monoblock for the sub. Truthfully you may get away with a four. Run the front two channels to the front and bridge the rear two for a sub and let your head unit handle your rear speakers. The front are what really need to be amplified.
  8. #8 Re: quick question aboutan amp
    Feb 2009
    Virginia
    Hard to beat the quality of that Image Dynamics amp. Don't worry about what the specs say....it's got enough power to give you what you want.
    11 is louder than 10!
  9. #9 Re: quick question aboutan amp
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Not only will it be more than enough power for a great system. One thing to keep in mind here is space usage and ease of installation. A multi amplifier system is more involved since your running power, ground, turn on wires and RCA's to multiple. Not only that but you have to find a place for both of them. Just keeping that in mind, if you don't need more than a moderate amount of power, a single 5 channel amplifier would be perfect.
    Infinity all around.
  10. #10 Re: quick question aboutan amp
    Brookings, SD
    Ok, thanks! Ill go with the 5 ch
  11. #11 Re: quick question aboutan amp
    Quote Originally Posted by natethegreat View Post
    Sounds like a great plan! No figure out exactly which speakers you want to go with and I know us guys on here including myself would be happy to help find the perfect amplifier that fits the needs of the system you want.
  1. Quick WOT question
    By DanPrixGTP in forum General Tech Discussion
    Last Post: 12-09-2011, 09:10 PM
  2. Quick question on 97 gtp
    By Griitz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2009, 11:02 AM
  3. Quick Question
    By Bakerdd in forum General Tech Discussion
    Last Post: 07-18-2009, 12:03 AM
  4. Quick Question
    By High Rolling GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2009, 01:13 PM
  5. just a quick question
    By FtBll Coach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-21-2009, 10:04 AM
