Hey, i was wondering if i can get away with using onelarge amp to run the doors/6x9's/1-210 inch subs? or woukdbe better yo just run two separate amps? Thanks!
How much power do you need?
Image Dynamics i2600 5-Channel Class AB i Series Car Amplifier
Do you have any subs in mind? A couple of low-powered 10s would do nicely on that 5-channel 2000GTGP just posted.
Just check your prices comparing a five as compared to a two and a monoblock for the sub. Truthfully you may get away with a four. Run the front two channels to the front and bridge the rear two for a sub and let your head unit handle your rear speakers. The front are what really need to be amplified.
Not only will it be more than enough power for a great system. One thing to keep in mind here is space usage and ease of installation. A multi amplifier system is more involved since your running power, ground, turn on wires and RCA's to multiple. Not only that but you have to find a place for both of them. Just keeping that in mind, if you don't need more than a moderate amount of power, a single 5 channel amplifier would be perfect.
