Thread: Help with factory wiring
Results 1 to 4 of 4
Threaded View
izup69 Help with factory wiring 02-06-2012, 12:19 AM
BillBoost37 Re: Help with factory wiring 02-06-2012, 06:37 AM
izup69 Re: Help with factory wiring 02-06-2012, 03:44 PM
KeithGTP03 Re: Help with factory wiring 02-07-2012, 01:19 AM
  1. #1 Help with factory wiring
    Destroys cars izup69's Avatar
    Iowa
    Ok so here is the story my 97 prix is wired to hell from the prev owner. I don't want to have to take the hole head-unit and amp system out.The front door speakers are hooked up to the factory wires. But the amplifier is wired into the the stock mid's wiring. If I unplug the 2 front channels on the amp the front speakers still work. When I unplug the rear channels the front speakers go dead. Well that's not really a problem. The problem I have is how in the hell can you wire the rear mid's into the factory fronts.
    I don't want to destroy a pair of $120 speakers by just putting them in wired the way they are because I don't know if they will get the correct wattage. I know im going to have to rip everything out and redo the hole dam system so I can actually get the front speakers on there own channel and so forth. But for now its cold out and the ground is soaking wet and im in the process of buying a house. So I just want to get them put in temporally until I get a warm dry place to do stuff lol.
    I just cant figure out for the life of me how they got the speakers wired in. All the info I have looked at only tells me the wire colors for the front 2 and the rear 2 not the mid's. On another note when I took the door panel's off today the tweets are not even hooked up nor is there a plug to plug them in to like it just disappeared lol. I looked all over in the doors and everything but nota. I just want to get everything hooked up strait so I can actually tune the audio system. I cant find a wiring blueprint I can find the diagrams but not a blueprint. Like where dose the rear mid's and front door speakers wire together.
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  1. FACTORY MONSOON WIRING DIAGRAM for Audio system Install using LOC
    By ivorywhiteRIC in forum Audio, Security & Visual Electronics
    Last Post: 04-05-2015, 08:16 AM
  2. are these factory rims?
    By spider4 in forum Tires & Wheels
    Last Post: 11-25-2011, 08:03 PM
  3. Factory amp in a 1996 se
    By fearless in forum General Tech Discussion
    Last Post: 04-29-2010, 07:26 PM
  4. Factory Radio
    By cmw1876 in forum General Tech Discussion
    Last Post: 04-22-2009, 03:19 PM
