Thread: How to stop the WHineing
Results 1 to 20 of 35
  1. #1 Re: How to stop the WHineing
    Saraland Alabama
    engine whine is a ground loop, running power lines with rca's won't cause it unless running garbage (a guy who won sq finals in iasca proved that theory wrong a while ago as he had everything in a bundle to prove it) a cap can help as that is basically what a ground loop isolator is (just hook it up on the ground instead of the power) I always grounded mine together (used a distribution block even on the competition vehicles, and was the preferred method at the time) keep the grounds short as they can act as an antenna
  2. #2 Re: How to stop the WHineing
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    Yea I have seen ppl bundle it too but I guess I'm just a creature of habit. Couldnt agree more that RCAs are about 90% of the noise most the time. Anyways noise sucks hope you get it cleared up.
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  3. #3 Re: How to stop the WHineing
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    Well I am going to get some good RCA Cables hopefully that is my problem I have kind of cheap ones now and thought that it would be OK if I ran them seperate from the Power I am running the RCA's on the Drivers side and the power on the pass side. What kind of RCA's do you recommend
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  1. Stop slammin my doors!!!!!!
    By Freebeer187 in forum The Rant Forum
    Last Post: 04-17-2009, 07:45 AM
  2. Low idle at Stop Sign
    By offroadfury6 in forum General Tech Discussion
    Last Post: 08-10-2008, 06:26 PM
  3. running a stop sign
    By tod1d in forum The Rant Forum
    Last Post: 08-06-2008, 06:48 PM
  4. Do oil treatment additives actually stop leaks?
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 04-08-2008, 02:17 PM
