Thread: Putting in a switch for subwoofers
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 78
  1. #1 Putting in a switch for subwoofers
    GT Level Member EJRJR91's Avatar
    Nanuet, NY
    Hey guys, so i plan on buying two 10 inch subs with an amp and a capacitor. Already decided on which im getting. My question for everyone is whether or not theres a way to wire all this to my aftermarket head unit but also put in a switch so im not blasting the subs all the time and so i can turn off the amp when the cars off so i dont drain the battery. Any help is appreciated. Dont be afraid to dumb it down lol.
    2002 Pontiac Grand Prix SE --> Audio, Lighting, Exterior
  2. #2 Re: Putting in a switch for subwoofers
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    get a switch.. and have it connect ya remote wire to ya amp and cdplayer... flip it on you got bass flip it off you got stock insides
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  3. #3 Re: Putting in a switch for subwoofers
    Buffalo
    if its hooked up to the remote wire from the headunit, then it will turn off when the car is off
    Or get a bass knob Tune your system so the half way point on the knob is "normal" then back it down for no bass from the subs. I do this whenever I have people in the car or coming up to traffic at light
  4. #4 Re: Putting in a switch for subwoofers
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    You could do what GTPSHAWTY said or run a power wire to the switch then run a wire from the other part of the switch to the amp.
  5. #5 Re: Putting in a switch for subwoofers
    Bunnell, FL
    i've always just switched the remote turn on wire
    if there isn't any voltage going thru the wire the amp won't "turn on"
    I'm a Sex Offender
    Buffalo
    Head units typically have a sub on/off option in the menu
  7. #7 Re: Putting in a switch for subwoofers
    GT Level Member nicks98gtp's Avatar
    michigan
    ^^ this. all the headunits ive ever had even the cheap one i used from walmart for a while had a sub on/off option or at least a subwoofer lever so when turned all the way down they didnt hit at all
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
  8. #8 Re: Putting in a switch for subwoofers
    Jun 2011
    ontario
    i just wired in a switch. its easy and faster then messing with the head unit.
  9. #9 Re: Putting in a switch for subwoofers
    Nanuet, NY
    so simply connecting the amp to the headunit by the remote control wire, a long wire lol, would have it go off with the head unit and prevent a battery drain? Sorry for repeating that lol I drive 30 miles everyday to the city and would hate to kill the battery, not many people are willing to help jump it in the city nor is a tow exactly cheap
  10. #10 Re: Putting in a switch for subwoofers
    Jun 2011
    ontario
    turn off your head unit and see if the power light on your amp is on or off. that will tell ya fast
  11. #11 Re: Putting in a switch for subwoofers
    SE Level Member ttjj1410's Avatar
    Nov 2011
    fairbanks, ak
    Bass Knob if you want to be able to adjust the bass up and down. switch if you want to turn it on and off completely. problem solved
  12. #12 Re: Putting in a switch for subwoofers
    GTP Level Member
    springfield IL
    Forget about using the switch.... Ask your self why your using a WASTEFUL cap..?!?!!They do more harm than good on your electrical. Get a 2nd bat
  13. #13 Re: Putting in a switch for subwoofers
    GTP Level Member
    springfield IL
    Doubt you have high-end amps/subs.... Can prolly get by with just the factory bat.
  14. #14 Re: Putting in a switch for subwoofers
    Nov 2008
    Waterloo, Iowa
    Most amplifiers will not turn on without being wired to the head unit. So as long as the head unit is on, the amplifier is on. IF you still want to listen to music while you're driving and just have an amplifier "kill-switch", split your remote wire and hook it up to a switch, that way you can flip the subwoofers on and off without affecting the rest of your music to your heart's desire.
  15. #15 Re: Putting in a switch for subwoofers
    brunswick
    same thing i said sean... lol its hard callin you sean.. feeel like im talkin to myself (my name sean) but also op a cap is a waste of time two tens shouldnt be that powerful to where the batt dies/dim the lights... i had 3 12's w/1500 class d amp and never had a problem with the lights or batt die.. just throwing that out there
  16. #16 Re: Putting in a switch for subwoofers
    Nov 2008
    Waterloo, Iowa
    Quote Originally Posted by GTPSHAWTY View Post
    I get slight headlight dimming, and pretty heavy interior light dimming, but I also have terrible stock wiring. I plan to do a big 3 myself pretty soon though. I have more subs but less power. 4 12"s on 1000w RMS d-class amp. :P
    Also I used to be saw1833 on here, but I got tired of that. :P
  17. #17 Re: Putting in a switch for subwoofers
    Pennsylvania
    Quote Originally Posted by EJRJR91 View Post
    Hey guys, so i plan on buying ...a capacitor.
    That's a bad plan.
    Turn the volume down. Your sound quality sucks without your subs on anyway.
    The amp turns off when the radio turns off.
    If you want to listen to music with the car off, and you don't want to set it up with a battery in the trunk so you can keep the amp on, then yeah, go for the switch. But seriously, how much do you sit in the car listening to music for more than an hour?
  18. #18 Re: Putting in a switch for subwoofers
    Jun 2011
    ontario
    ok why is a cap a bad thing?
    i got a amp coming to me this weekend and i got a cap and thought it was a good thing....
    getting a Hifonics Brutus BRZ1200.1D.. hooking it upto 2 infinity 1240w reference subs in a sealed box. gonna run at 4 ohms i think
  19. #19 Re: Putting in a switch for subwoofers
    Pennsylvania
    A cap is an additional point of failure, and additional "noise." They don't help with sound quality of amps, or with power spikes of any reasonable kind. Get your cash back while you can.
  20. #20 Re: Putting in a switch for subwoofers
    Jun 2011
    ontario
    i got the cap a long time ago i just had it stored since my old amp died. but with my old setup in my old car the amp was hurting my electrical system and the cap stoped that. i didnt notice sound quality go bad since it was installed. ... are you saying its a bad idea with our cars? or just in general? i am searching for a stuff that explains why its bad but i cant find anything.
  1. So Who go F***ed on this deal? Subwoofers...
    By Brian99SE in forum General Grand Prix Discussion
    Last Post: 01-11-2012, 02:28 PM
  2. Can't get key out after putting car in park.
    By Dusty02se in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-11-2010, 02:44 PM
  3. Putting Motor In
    By dcbur2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2009, 10:44 AM
  4. 10 inch digital dynamics subwoofers
    By gtpinsc in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2008, 02:20 PM
