So I've almost completed the circuit for my little project, but I just need to double check on a few things before I actually order the pieces, build, test, etc.
C1-A: provides constant +12v
C1-B: requires +12v to crank the starter
C1-D: provides +12v when a key is detected in the ignition switch (is this also post-PK3 logic???)
C2-A: provides constant +12v
C2-B: requires +12v when you want the vehicle to be on, cut power to this if you want to shut the vehicle off
C2-C: requires +12v when you want the accessories to be on (stereo, HVAC, etc), cut power to this if you want to turn the accessories off
C2-E: chassis ground
The reason I'm asking this here is so that I don't have to go rip my car apart just to test voltage scenarios. If all else fails I guess I'll have to do it anyways, but I figured somebody on here would know these things.
